It is currently Thu Jul 03, 2025 10:56 am
Reply to topic  [ 1 post ]
 GTR 37 XD Power Trim Issue
Post GTR 37 XD Power Trim Issue
Model 2016 GTR 37 XD. A few months back, my trim unit started acting up. It trims up fine, but it trims down super slow. If it sits for a minutes with being trimmed, and I hit the down button, it wont even move. I have to bump the up trim then hit the down trim for it to trim down. Then it's a super slow process going down. Its affecting my maneuverability. Has this happened to anyone or has anyone tried to work on the trim unit? (Add oil) I did take both flat-head screw plugs out to check the oil level and oil came out as soon as it was cracked open. It doesn't really look the same as the ones I've researched. There is a needle valve under each cap which I guess work as a check valve. Not sure though. Ram looks good, unit sounds good for the most part. It sounds like the motor is spinning just a little bit slower on the down trim, but not much. Any ideas?
Sent from my SM-G892A using Tapatalk
Thu Jun 13, 2019 8:54 am
Users browsing this forum: Google [Bot] and 61 guests
