| Mud buddy carnage http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=74017 |
| Author: | vertical_edge_800 [ Wed Jul 24, 2019 11:17 am ] |
| Post subject: | Mud buddy carnage |
I bought this motor from a fella who had insurance on his boat. He was rear ended by another boat and it tore up the motion base a bit. I’ve welded a bunch of cast aluminum- and the aluminum used on these motion bases welds almost exactly like billet aluminum! None of the nasty black porosity that I’m accustomed to. I’ve taken it out for a test run... all seems good. End up making a jig to hold it all together, ground out two of the bolt threads and filling them with weld so I could drill and tap them again as the break went through each bolt. The only thing I’m not too sure about is the temperature of the motion base / clutch cover. Seems like it gets pretty warm- like 125* or so. Is that normal? |
| Author: | Will C [ Wed Jul 24, 2019 1:54 pm ] |
| Post subject: | Re: Mud buddy carnage |
Badass save! Lol. They get a little warm from belt friction and reverse but not bad. Just service the reverse often. Watch the belt wear pattern |
| Author: | AKGOBLUE [ Tue Jan 21, 2020 3:11 am ] |
I can tell you, that was not a fun day in the water. I was in the boat that hit him, as a passenger. A little too much throttle and not paying attention, could have ended up much worse. Glad to see the motor get back to work. |
