| GTR parker trim problems http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=74098 |
| Author: | jc [ Fri Aug 16, 2019 6:56 pm ] |
| Post subject: | GTR parker trim problems |
I need to know how to add fluid to a parker trim unit. Last trip out the cap on the rod came loose and it leaked a good bit of fluid out. I have searched on here and at their web site and have only found a instruction manual, but it doesn't show how to add fluid. They say its sealed for life, but if that were the case I wouldn't need to add fluid. |
| Author: | jc [ Fri Aug 16, 2019 7:12 pm ] |
| Post subject: | Re: GTR parker trim problems |
I have taken off the large screws on the front and back but they are for check valves. |
| Author: | jc [ Fri Aug 16, 2019 7:19 pm ] |
The only place I have not found a valve is this hole on the end. It is only about 3/16 and I don't think this is the fill hole. Any suggestions? |
| Author: | jc [ Mon Aug 19, 2019 4:26 am ] |
Does anyone have a suggestion on what type of fluid? The fluid that leaked out looks like transmission or power steering fluid. |
| Author: | jc [ Tue Aug 20, 2019 6:00 pm ] |
Someone has to have worked on one these. Any suggestions? |
| Author: | Russ [ Tue Aug 20, 2019 6:11 pm ] |
So, why not just take the 5 mins and call gatortail and ask? No one that's read your post has the answer, but I bet gatortail does. #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | MaXXis85 [ Wed Aug 21, 2019 6:59 am ] |
They will tell you only the motor is serviceable the rest isn't. |
| Author: | jc [ Wed Aug 21, 2019 5:45 pm ] |
All their info I found says that, and it also says it's sealed for life but I disagree. If you take the motor off you can add fluid. I used atf. |
| Author: | luckyhat12 [ Wed Jan 19, 2022 4:38 pm ] |
@jc - based on your picture I'm guessing that the unit needs to be completely removed and the rod extended to add oil there. |
| Author: | jc [ Wed Jan 19, 2022 7:18 pm ] |
It has to be standing up to fill it. The rod needs to be fully retracted or you will overfill it. Mine has been working fine since I add the fluid. |
| Author: | luckyhat12 [ Fri Jan 21, 2022 11:10 am ] |
