Duke3131
Pro-drive prop
What is the best way to determine the condition of your prop? I know kinda dumb question but I have several that I'm looking over. I just took delivery of a new one as well & it doesn't look a bunch different from 1 I already have. They certainly aren't like my outboards for visual inspection or at least for me. '
Fri Aug 23, 2019 10:39 am |
Wchauvin
Re: Pro-drive prop
Take your new one and measure from end to end and blade width. Compare that to your other props to see how worn they are. Also, if the cup is starting to flatten out, it’s time to get them cupped. Also, I’m sure they need to be sharpened. If you have any questions, feel free to pm me bro and I can try and help you out
Fri Aug 23, 2019 7:57 pm |
dead animal
Re: Pro-drive prop
it don't take much to wear out a prop. a couple beers and a sand bar and it's a $350 learning curve. lol
Fri Aug 23, 2019 8:25 pm |
Wchauvin
Re: Pro-drive prop
^ that’s the truth for sure lol cypress knees have always been my bane too. I tear my props up bad trying to get in my little socalet spots lol
Fri Aug 23, 2019 8:44 pm |
EGood
Re: Pro-drive prop
Hey Wchauvin. What prop would you recommend. 1860 Phowler, gen3 Pd, has the so called E5 build from PD. I sent y’all my original 3 blade several years ago but I can’t remember what y’all did to it. What ever it was it made a huge difference in speed, vibration, and hole shot. Does a 14p double cup sound about right. I usually stay around 4250-4300 rpm.
Sat Aug 24, 2019 8:51 am |
Will
Re: Pro-drive prop
Yep, I burned one last night in about 3 minutes, 11.5" after a sand bar with river pebbles. After that, I'm running back to the ramp 3/4 throttle, trimmed down like and outboard, turning 4900rpm and only running 22mph...it's obvious when they're BURNT hahaha
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Sat Aug 24, 2019 2:20 pm |
Wchauvin
Re: Pro-drive prop
Stock PD bro or performance work done?
Sat Aug 24, 2019 7:29 pm |
EGood
Re: Pro-drive prop
Cam, heads, performance tune, exhaust and high flow filter.
Sat Aug 24, 2019 8:07 pm |
Wchauvin
Re: Pro-drive prop
14 pitch depending on your gear ratio. I’f you aren’t turning 2-1 I would run a 13 with heavy cupping and sharpened blades so that you don’t sacrifice load carrying ability and holeshot
Sat Aug 24, 2019 8:54 pm |
EGood
Re: Pro-drive prop
It’s the 2-1 gearing. Thanks.
Sun Aug 25, 2019 5:08 am |
banded-mallard
Re: Pro-drive prop
Mon Aug 26, 2019 3:29 am |
Wchauvin
Re: Pro-drive prop
^ correct. I assumed that he was talking about a stock prop, if it is pitched, it will be roughly 1/8th of an inch of diameter tip to tip per inch of pitch added. Because people pitch differently and measure differently, it could be more of 1/16th or 1/8th, but somewhere in that area
Mon Aug 26, 2019 4:38 am |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
Re: Pro-drive prop
Do any of the prop shops sell stock Prodrive props (Gen 2) that have been properly balanced?
Tue Aug 27, 2019 1:22 pm |
Wchauvin
Re: Pro-drive prop
We have some from time to time and may have some in stock if you would like me to check tomorrow bro. No prop out the box will be perfectly balanced, some are close, but almost all have to be adjusted
Tue Aug 27, 2019 6:37 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Re: Pro-drive prop
It really don’t matter what you do your prop,A Poodrive is going to be a turd
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Thu Aug 29, 2019 7:11 pm |
