It is currently Sat Feb 21, 2026 6:22 pm
[ 4 posts ] |
GTR Prop Shaft Leaking Grease
duck7878
Just came in on opening day and noticed a bunch of grease (a couple tablespoons) coming out of the prop shaft just below the nut in the picture where the prop shaft attached to the housing. Any ideas what is going on? I imagine it can’t be a simple seal issue based on the location. I had just changed ed my grease and I did pull the screw before greasing it.
| Sat Oct 19, 2019 11:23 am |
Bayou black hunter
 Re: GTR Prop Shaft Leaking Grease
Your tube is prolly cracked,
Sent from my SM-G892A using Tapatalk
_________________ Using Tapatalk
| Sat Oct 19, 2019 4:42 pm |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
Take her to the shop to get checked out.
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
| Sat Oct 19, 2019 9:16 pm |
MaXXis85
Tube is cracked. You need a new tube and flange assembly.
| Mon Oct 21, 2019 7:16 am |
[ 4 posts ] |
