| Cutting the skeg? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=74782 |
| Author: | ducktank23 [ Mon Dec 09, 2019 9:30 pm ] |
| Post subject: | Cutting the skeg? |
I saw a post by Willie Fast the other day about cutting the skeg a bit to get more water to the prop. I looked up the performance skeg and it appears a simple cut should do it but I don’t want to go grinding away on my skeg. I also want to hear some feed back with people with experience with it and if it’s really worth the hassle. I’ve got a 2018 GTR37 XD for reference. |
| Author: | Wchauvin [ Tue Dec 10, 2019 7:46 pm ] |
| Post subject: | Re: Cutting the skeg? |
It’s worth it. Willey’s templet is the correct one for performance. It really makes a little difference when paired with a worked prop but only after the skeg has been cut. Don’t get a prop worked and then cut the skeg because it changes the working rpms |
| Author: | mizzippi jb [ Sun Dec 15, 2019 6:06 am ] |
Where did you see this post? Link? Thx Sent from my SM-G973U using Tapatalk |
| Author: | ducktank23 [ Mon Dec 16, 2019 2:00 pm ] |
If you google, Willie Fast Performance Prop, it’ll bring up his Facebook post. I have a screenshot I’ll post |
| Author: | mizzippi jb [ Mon Dec 16, 2019 2:07 pm ] |
Thanks. Prob not much to be done with the cast skeg I'm guessing. Sent from my SM-G973U using Tapatalk |
| Author: | ducktank23 [ Mon Dec 16, 2019 2:23 pm ] |
I actually went ahead and did this. A new skeg is only $65 so I figured it was worth the risk. Haven’t had a chance to test the performance or speed increase but it was pretty simple to remove the lower skeg bolts and make the cut and sand it smooth. Took maybe 45 minutes |
| Author: | Roostertail3 [ Mon Dec 16, 2019 2:42 pm ] |
Takes 5 min to do so I figured it’s worth a shot. With a stock 40xd motor and stock prop I didn’t really gain any performance, it did hurt. I have a prop getting worked now so I’ll update when I run it. |
| Author: | Will [ Mon Dec 16, 2019 8:15 pm ] |
I did this years ago on the Prodrive to allow more vegetation and muck to the prop for 4wd but I guess you open water gtr pirates wouldn't know about that. Sent from my Pixel 2 using Tapatalk |
| Author: | ducktank23 [ Mon Dec 16, 2019 10:41 pm ] |
You know I looked into getting a Prodrive once, but I don’t have a vagina so I got a Gatortail #cantbuyunderwearballsdontfit |
| Author: | bluesky2012 [ Mon Dec 16, 2019 10:59 pm ] |
| Author: | ducktank23 [ Tue Dec 17, 2019 12:06 am ] |
If I asked for a good comeback, I’d scrape it off your mother’s teeth. But I am glad you took the time to look up my post to see I have a Havoc |
| Author: | Russ [ Tue Dec 17, 2019 7:50 am ] |
O_o #CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor |
| Author: | Wchauvin [ Tue Dec 17, 2019 8:14 am ] |
Recklessness |
| Author: | brycecheramie [ Tue Dec 17, 2019 8:33 am ] |
BuT I CaN BaCk Up In DeEp WaTeR |
| Author: | mizzippi jb [ Wed Dec 18, 2019 8:26 am ] |
I ain't waiting for that lower to spin around wiggling thru this shit, hydro or ratchet either one. It's all about what you need for where you play Sent from my SM-G973U using Tapatalk |
| Author: | Wilson [ Fri Dec 20, 2019 1:13 pm ] |
Does anyone have a template for a modified Prodrive skeg? |
| Author: | ducktank23 [ Fri Dec 20, 2019 6:20 pm ] |
Can you send a picture of your skeg? From what I can tell from mine, the part I can out lines up even with my prop just so water can use the whole prop. If you send a pic I may be able to help you out. You also might be able to message Willie Fast and see what he says since he actually knows what he’s doing |
| Author: | SP [ Mon Dec 23, 2019 5:09 pm ] |
| Author: | Will [ Mon Dec 23, 2019 9:04 pm ] |
| Author: | Will [ Mon Dec 23, 2019 9:09 pm ] |
Here my old one, cut cavitation plate and modded skeg Sent from my Pixel 2 using Tapatalk |
| Author: | ducktank23 [ Fri Jan 03, 2020 1:11 pm ] |
Wanted to post an update since I got to take a test run on flat water and see what the difference was. Flat water with no current I saw again of roughly 1.5-2mph. The biggest difference was it made it a lot easier to steer with my tiller handle and seemed to take some of the torque and push I always had. Only downside, which really isn’t one, is the rooster tail isn’t as “wide” as before, but it’s still pretty high. Overall I’m pretty stoked with the results. |
