It is currently Fri Feb 20, 2026 11:55 am
[ 7 posts ] |
Stage 1 gtr 40xd props suggestions
duckhead75
So what prop should I consider to run on a stage 1 40? It's on a 17x50 predator. I'm looking for a little more speed. 31sown river 28ish up river with moderate load. That with either 2 blade or 3 blade. 4650 rpm with 2 blade ca57 10p 4600ish Rpm 3 blade Ca49 11p. That's with the pin in the 3rd hole from the top. 3 blade has some hours on it. 2 blade is new but it looks like I could pull more cup??
| Fri Dec 27, 2019 9:19 pm |
Russ
 Re: Stage 1 gtr 40xd props suggestions
Get some prop work done. LaProp or Baggy.
#CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor
| Fri Dec 27, 2019 10:00 pm |
duckhead75
What does it take to swing a hammer or raptor?
| Sat Dec 28, 2019 2:06 pm |
Russ
You can swing them now. They're a lot of metal. Harder on bearings. You can get load carrying and speed with a big blade or stock gtr 2 blade. No need for the extra metal unless you run alot of mud and want the extra wear.
| Sat Dec 28, 2019 2:24 pm |
duckhead75
Thanks Russ. I dont need the extra wear for sure. Just looking to get in the 30s.
Change of topic, Is the OTC leak down tester is worth a crap?
| Sat Dec 28, 2019 2:30 pm |
Russ
It's what I have. No more than I need it, it's working fine.
| Sat Dec 28, 2019 3:43 pm |
bluesky2012
| Sat Dec 28, 2019 5:22 pm |
[ 7 posts ] |
