| PD Sticking clutch http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=75166 |
| Author: | LTChaser [ Sat Jun 20, 2020 7:37 pm ] |
| Post subject: | PD Sticking clutch |
Just installed a new clutch on my gen 3. Once motor has run awhile clutch won’t engage without a light blip of the throttle. Won’t engage with key in on position, until cooled down. Checked all connections. On da bayou now frogging, so yup.. this sucks Sent from my iPhone using Tapatalk |
| Author: | caddobrook [ Tue Jun 23, 2020 1:06 pm ] |
| Post subject: | Re: PD Sticking clutch |
Sounds like a connection issue.. Also might check to make sure line didn't get pinched in install. It is easy to do and has been done before... |
| Author: | LTChaser [ Tue Jun 23, 2020 6:32 pm ] |
You are 100% correct Just finally got to it this evening. Turned out being two things. Double purple wire in control box had a weak connection and corrosion on negative connection to pigtail. Replaced with new water proof connectors and now working great. Ready for the frogs again..! Sent from my iPhone using Tapatalk |
