It is currently Wed Mar 11, 2026 4:48 pm
[ 5 posts ] |
Big block 25 get prop question.
2WIDGN
I bought an extra prop when I picked up my rig at Delta performance. The stock prop is a two blade 10 pitch and the extra prop is a worked three blade 11 pitch. I run the three blade 11 most of the year. 3800 rpm's gives me good speed and handles a load well. This time of year I put the two blade ten on. It's thicker edges handle the hard stumps and other hard stuff better. It runs higher rpm's to achieve similar performance to the three blade...4300-4400. I keep it backed off most of the time. If I buy a two blade in a higher pitch (11) can I get my rpm's down and get better performance?
| Thu Oct 21, 2021 10:09 am |
2WIDGN
 Re: Big block 25 get prop question.
Title should read GTR...not get...
| Thu Oct 21, 2021 10:11 am |
Wchauvin
Just get that 2 blade worked, add an inch of pitch, sharpen, balance, and that should bring your Rpms to around 3900-4100 and give you a little more on the top end if that’s the rpm range you are looking to achieve. Call baggy and he can take care of that for you. 985-868-0103
| Fri Oct 22, 2021 6:37 am |
2WIDGN
Thanks. What's the turn around time on work like that?
| Fri Oct 22, 2021 10:55 am |
Wchauvin
2-3 weeks bud
| Sat Oct 23, 2021 8:33 am |
[ 5 posts ] |
