SETX GDSD repair needed http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=75662 |
Author: | shooter1 [ Tue Apr 27, 2021 7:27 pm ] |
Post subject: | SETX GDSD repair needed |
I’m new to the mud boat scene and need some lower unit work done on a 2014 35hp GDSD. Who’s the go to guy out there? |
Author: | matttwad [ Tue Apr 27, 2021 7:53 pm ] |
Post subject: | Re: SETX GDSD repair needed |
Probably a few guys out there who will do it on the side but I do know heritage marine in Beaumont and northshore marine in NE Houston are options. It’s a bit of a drive but I’ve drove to Godevils shop in Baton Rouge and had them swap out shaft, gears and all the seals in a day, had it there at 10 and they were done at 4 and I was back in business. Sent from my iPhone using Tapatalk |
Author: | Gigafowl [ Wed Apr 28, 2021 4:24 am ] |
Author: | Russ [ Wed Apr 28, 2021 5:00 am ] |
Marcus at Bayou Surface Drives is in Cleveland, Tx. #CFFITR #mudmotor>physics |
Author: | shooter1 [ Wed Apr 28, 2021 8:56 am ] |
If I take this thing to Heritage what should I expect to pay? I know the sprocket bearing is the immediate issue and I assume I might as well replace all the seals. |
Author: | Gigafowl [ Wed Apr 28, 2021 10:15 pm ] |
Let them tell you ! You might need a new shaft if no maintenance has ever been done as the rear seals can cut into the shaft if it has been poorly greased and maintained.... It can be 200 to 300 if there is bad news on all counts.... Just depends on what they see inside there on seals bearings U-joints etc.... If Jerimiah is still there he knows his stuff ! |
Author: | kib876 [ Thu Apr 29, 2021 4:49 am ] |
Last fall Jeremiah was still there. Rick and the team at Heritage are good folks. |
Author: | shooter1 [ Thu Apr 29, 2021 7:23 pm ] |
Thanks for the input guy’s, I’ll run it over to heritage tomorrow. |
