| Big block 25 get prop question. http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=75780 |
| Author: | 2WIDGN [ Thu Oct 21, 2021 10:09 am ] |
| Post subject: | Big block 25 get prop question. |
I bought an extra prop when I picked up my rig at Delta performance. The stock prop is a two blade 10 pitch and the extra prop is a worked three blade 11 pitch. I run the three blade 11 most of the year. 3800 rpm's gives me good speed and handles a load well. This time of year I put the two blade ten on. It's thicker edges handle the hard stumps and other hard stuff better. It runs higher rpm's to achieve similar performance to the three blade...4300-4400. I keep it backed off most of the time. If I buy a two blade in a higher pitch (11) can I get my rpm's down and get better performance? |
| Author: | 2WIDGN [ Thu Oct 21, 2021 10:11 am ] |
| Post subject: | Re: Big block 25 get prop question. |
Title should read GTR...not get... |
| Author: | Wchauvin [ Fri Oct 22, 2021 6:37 am ] |
Just get that 2 blade worked, add an inch of pitch, sharpen, balance, and that should bring your Rpms to around 3900-4100 and give you a little more on the top end if that’s the rpm range you are looking to achieve. Call baggy and he can take care of that for you. 985-868-0103 |
| Author: | 2WIDGN [ Fri Oct 22, 2021 10:55 am ] |
Thanks. What's the turn around time on work like that? |
| Author: | Wchauvin [ Sat Oct 23, 2021 8:33 am ] |
2-3 weeks bud |
