It is currently Tue Jun 16, 2026 11:23 am
Reply to topic  [ 26 posts ]
 Prodrive Clutch
Post Prodrive Clutch
When just drifting around clutch holds but put a load it feels like it slips and won't hold the power. Anyone experience this? If the clutch I saw an aftermarket some where?
Sent from my SM-G928V using Tapatalk
Sat Jun 17, 2017 9:58 am
Post Re: Prodrive Clutch
What do you mean the clutch wont hold power?
As in electrical power?
Sat Jun 17, 2017 5:07 pm
No as in when the throttle is nailed it slips.
Sat Jun 17, 2017 6:08 pm
Do you have high rpm's just not going anywhere?
Give us more info on what its doing to make you think its slipping
Sat Jun 17, 2017 6:21 pm
When going to get up on step and giving it more throttle it starts high trying without going anywhere.
Sat Jun 17, 2017 7:00 pm
Sat Jun 17, 2017 7:03 pm
Thought that myself. Took a prop off my buddies boat that was ran and did the same thing.
Sat Jun 17, 2017 7:05 pm
Hmm.
Have you greased the lower unit lately?
I ask because you could have over greased it and there is grease on the clutch.
Sounds like you may be pulling the powerhead to inspect it. Might have a loose clutch bolt
Sat Jun 17, 2017 7:10 pm
Yea I'm going to pull the powerhead and inspect the clutch. What's the best option for a replacement?
Sat Jun 17, 2017 7:14 pm
Sat Jun 17, 2017 7:19 pm
Blueshamu has a thread somewhere on here. He's running something different, too.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Sat Jun 17, 2017 7:27 pm
Xtreme Outdoor Power....they have a replacement for the PD clutch.
Sun Jun 18, 2017 8:01 pm
Yeap, that's the link I posted. Comes from Xtreme
Sun Jun 18, 2017 8:17 pm
Mon Jun 19, 2017 4:20 am
Appreciate it guys. Got it ordered.
Mon Jun 19, 2017 5:03 am
Call Xtreme direct...make sure you are getting the right clutch. They may want you to measure the crank length.
Mon Jun 19, 2017 5:21 am
Ok it's for a Gen 4 w/ 37EFI.
Mon Jun 19, 2017 6:49 am
Hmmm. That may be the wrong one then. I know they started with a heavy duty clutch. Don't know if that matters or not.
Mon Jun 19, 2017 7:00 am
I've ran one of their clutches for the past year, somewhere in the ball park of 70+ hours with no problems.
Mon Jun 19, 2017 6:45 pm
Little update. I cancelled the order with extreme powersports. I talked to their guy and he was not sure if he had what I needed so I gave Nick Peltier a call and ordered the one from prodrive. I did fine out it is the new heavy duty one. I'm ready to get this thing back on the lake. By the way any parts call Nick he is jam up.
Tue Jun 20, 2017 5:05 am
New clutch installed and all problems are gone. New clutch was very easy.
Mon Jun 26, 2017 7:21 am
Awesome!
Glad you got it all done correctly
Mon Jun 26, 2017 7:30 am
Do you mind giving a quick run down of the steps involved in changing it? I've never heard anyone call it "very easy" before, but I've never done it.
Mon Jul 03, 2017 4:14 pm
Mon Jul 03, 2017 8:03 pm
I hit an object in to water with mine and the 4 bolts holding the spline adapter together shired off !
Thu Apr 14, 2022 7:23 am
PS : with no load on it the prop would turn but not under load !
Thu Apr 14, 2022 7:25 am
