It is currently Fri Mar 20, 2026 12:54 pm
Reply to topic  [ 11 posts ]
 GTR parker trim problems
Post GTR parker trim problems
I need to know how to add fluid to a parker trim unit. Last trip out the cap on the rod came loose and it leaked a good bit of fluid out. I have searched on here and at their web site and have only found a instruction manual, but it doesn't show how to add fluid. They say its sealed for life, but if that were the case I wouldn't need to add fluid.
Fri Aug 16, 2019 6:56 pm
Post Re: GTR parker trim problems
I have taken off the large screws on the front and back but they are for check valves.
Fri Aug 16, 2019 7:12 pm
The only place I have not found a valve is this hole on the end. It is only about 3/16 and I don't think this is the fill hole. Any suggestions?
Fri Aug 16, 2019 7:19 pm
Does anyone have a suggestion on what type of fluid? The fluid that leaked out looks like transmission or power steering fluid.
Mon Aug 19, 2019 4:26 am
Someone has to have worked on one these. Any suggestions?
Tue Aug 20, 2019 6:00 pm
So, why not just take the 5 mins and call gatortail and ask? No one that's read your post has the answer, but I bet gatortail does.
#GhostBoat
Tue Aug 20, 2019 6:11 pm
They will tell you only the motor is serviceable the rest isn't.
Wed Aug 21, 2019 6:59 am
All their info I found says that, and it also says it's sealed for life but I disagree. If you take the motor off you can add fluid. I used atf.
Wed Aug 21, 2019 5:45 pm
@jc - based on your picture I'm guessing that the unit needs to be completely removed and the rod extended to add oil there.
2054 WC Custom CC pushed by a GTR
Wed Jan 19, 2022 4:38 pm
It has to be standing up to fill it. The rod needs to be fully retracted or you will overfill it. Mine has been working fine since I add the fluid.
Wed Jan 19, 2022 7:18 pm
Fri Jan 21, 2022 11:10 am
cron
