It is currently Sun Jul 13, 2025 11:22 pm
Reply to topic  [ 5 posts ]
 strange noise from clutch
Post strange noise from clutch
Got a 32 hp PD with 160 hours with a new lower unit with only about 25 hours on it and my clutch has started to make a strange noise after it disengages while using the pulse switch. It sounds like something maybe coming loose and makes a strange sounding vibration but it only does it some times. Any thoughts on whats causing it?
Fri Mar 05, 2010 8:38 pm
Post Re: strange noise from clutch
I would call KP at Prodrive. He is very helpful and can get you sorted out....
Fri Mar 05, 2010 9:02 pm
Fri Mar 05, 2010 9:12 pm
I experianced the same noise. Clutch went out a few hours later. Its not a good feeling knowing you cant get home due to the clutch not engaging.
They run just under 200 bucks and can be changed out in an hour if you are a little handy with tools.
Fri Mar 05, 2010 10:36 pm
Don't stray too far from Swansons to run those lines!
Check your inbox man.
Breaux skiff, 36 PD
Sat Mar 06, 2010 4:47 pm
Users browsing this forum: No registered users and 46 guests
