strange noise from clutch http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=8244 |
Author: | JW127 [ Fri Mar 05, 2010 8:38 pm ] |
Post subject: | strange noise from clutch |
Got a 32 hp PD with 160 hours with a new lower unit with only about 25 hours on it and my clutch has started to make a strange noise after it disengages while using the pulse switch. It sounds like something maybe coming loose and makes a strange sounding vibration but it only does it some times. Any thoughts on whats causing it? |
Author: | caddobrook [ Fri Mar 05, 2010 9:02 pm ] |
Post subject: | Re: strange noise from clutch |
I would call KP at Prodrive. He is very helpful and can get you sorted out.... |
Author: | craig [ Fri Mar 05, 2010 9:12 pm ] |
Author: | naj [ Fri Mar 05, 2010 10:36 pm ] |
I experianced the same noise. Clutch went out a few hours later. Its not a good feeling knowing you cant get home due to the clutch not engaging. They run just under 200 bucks and can be changed out in an hour if you are a little handy with tools. |
Author: | ff154 [ Sat Mar 06, 2010 4:47 pm ] |
Don't stray too far from Swansons to run those lines! Check your inbox man. |
