Threaded or Tapered http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=8454 |
Author: | Shep [ Tue Mar 16, 2010 12:34 pm ] |
Post subject: | Threaded or Tapered |
Do any of the surface drive propellers come tapered??? If so, what dimensions is the tapering? I have a conventional Louisiana mud boat and have been interested in some of those props but I can't tell if they are threaded like the long tail go-devil props or are tapered. |
Author: | coondik [ Tue Mar 16, 2010 1:02 pm ] |
Post subject: | Re: Threaded or Tapered |
pm machete31 he had a surface drive wheel taper bored & keyed to fit his rig (can't remember who did it for him) |
Author: | machete31 [ Fri Mar 19, 2010 9:02 am ] |
No, they either come 3/4" thread or hex. Baggy's in Houma can taper bore & key. If your shaft is 1" or larger any of the props with 3/4" thread can be done without an insert, smaller than 1" shaft he may have to put an insert in. I had him do a MB Tiger Prop with hex bore and he had to make an insert. Ended up costing amost as much as the prop. I plan on de-rigging my boat this year and will change to the hex shaft because that prop runs the best on my boat and all I will need to do is add pitch and cup. |
Author: | Shep [ Sat Mar 20, 2010 9:19 am ] |
Machete, you have a Louisiana style mudboat?? If so, where did you purchase the shaft from? Looks like I have to replace mine this year as the keyway has broken somewhat. |
