| gator tail belt http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=8598 |
| Author: | gr_elliott [ Mon Mar 22, 2010 10:22 pm ] |
| Post subject: | gator tail belt |
the belt on my motor broke clean in half the other day, so I guess i get to replace a belt. Looking at this thing it seems the only way to get the new belt on is to unbolt the lower unit so that the belt can slide over the sprocket (or gear or whatever its called). Is there a trick to get the belt on without having to undo the lower unit? Maybe a trick of the trade I am missing? |
| Author: | WestEndAngler [ Mon Mar 22, 2010 10:24 pm ] |
| Post subject: | Re: gator tail belt |
From what Hoyt was saying on Saturday after they removed GatorPoint's lower unit in like 2 min it was fairly easy to slide lower unit in and onto belt one man job Hoyt said... Call them up. |
| Author: | gr_elliott [ Mon Mar 22, 2010 10:34 pm ] |
kinda what I was thinking...just wanting to check with the more seasoned guy on here before I start twisting the wrench I have been known to make the simple things hard |
| Author: | BROOKS [ Tue Mar 23, 2010 8:36 am ] |
Just undo the 9 bolts thats 'round that spindle thang .... take it off ... loosen the 4 engine bolts so you git alittle slack ... take one bolt off the braken mechinizam fo the reverse so you can put new belt past it .... drop belt thru the belt house and at the bottom tie a strang to it so with one hand you can pull it down to git the sprocket started at the bottom. Once you git it on .... re-install all the above and then goes and HangTiddy !!! The whole job takes one beer and 'bout 15 minutes .... Hope this helps !!!! |
| Author: | craig [ Tue Mar 23, 2010 10:31 am ] |
X2 what Mr. Brooks has stated. The entire job can be done in about 15 mins. |
| Author: | Parran [ Tue Mar 23, 2010 1:07 pm ] |
If you had da real deal you no need a belt Parran's belt holds his pants up sha |
| Author: | th3 [ Sun Mar 28, 2010 9:54 am ] |
| Author: | bjg [ Wed Apr 07, 2010 11:33 am ] |
LOosen the motor mounts and remove the lower unit. Its easy. |
