gr_elliott
 gator tail belt
the belt on my motor broke clean in half the other day, so I guess i get to replace a belt. Looking at this thing it seems the only way to get the new belt on is to unbolt the lower unit so that the belt can slide over the sprocket (or gear or whatever its called).
Is there a trick to get the belt on without having to undo the lower unit? Maybe a trick of the trade I am missing?
| Mon Mar 22, 2010 10:22 pm |
WestEndAngler
MMT Moderator
 Re: gator tail belt
From what Hoyt was saying on Saturday after they removed GatorPoint's lower unit in like 2 min it was fairly easy to slide lower unit in and onto belt one man job Hoyt said... Call them up.
| Mon Mar 22, 2010 10:24 pm |
gr_elliott
 Re: gator tail belt
kinda what I was thinking...just wanting to check with the more seasoned guy on here before I start twisting the wrench I have been known to make the simple things hard
| Mon Mar 22, 2010 10:34 pm |
BROOKS
Joined: Tue Jan 13, 2009 9:46 pm Posts: 4596 Location: East TEXAN Proud
 Re: gator tail belt
Just undo the 9 bolts thats 'round that spindle thang .... take it off ... loosen the 4 engine bolts so you git alittle slack ... take one bolt off the braken mechinizam fo the reverse so you can put new belt past it .... drop belt thru the belt house and at the bottom tie a strang to it so with one hand you can pull it down to git the sprocket started at the bottom. Once you git it on .... re-install all the above and then goes and HangTiddy !!! The whole job takes one beer and 'bout 15 minutes .... Hope this helps !!!!
_________________ Git a Gator-Tail or ride in mines wake ...... MtrFact !!!!! '05 Model .... Still Number One on the Water !!!!
| Tue Mar 23, 2010 8:36 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: gator tail belt
X2 what Mr. Brooks has stated. The entire job can be done in about 15 mins.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Tue Mar 23, 2010 10:31 am |
Parran
 Re: gator tail belt
If you had da real deal you no need a belt Parran's belt holds his pants up sha
| Tue Mar 23, 2010 1:07 pm |
th3
Joined: Thu Feb 26, 2009 4:10 pm Posts: 173 Location: magnolia
 Re: gator tail belt
_________________ INSTANT REVERSE .....its like a power window, you could live without it, but why bother!!!!
got two wooden nickels and a rabbit's foot, livin on luck like a small time crook.  i wear my soul like alligator skin, hard as leather with a toothy grin.
| Sun Mar 28, 2010 9:54 am |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: gator tail belt
LOosen the motor mounts and remove the lower unit. Its easy.
_________________ BUCK OFAMA
| Wed Apr 07, 2010 11:33 am |
