It is currently Sat Nov 15, 2025 11:27 am
[ 5 posts ] |
my lower bearing on my mudbuddy
TinySack
Joined: Mon Aug 03, 2009 4:43 pm Posts: 287 Location: south arkansas
the bearing behind the ole prop leaks grease. i was testing out the new exhaust with the boat trailered and is it ok that a little grease comes out of the bearing or is the bearing shot
_________________ Starting to wonder why my mother always called me special. 1750 GatorTrax HDeck 45 performance v-twin marshmellow double barrel exhaust premium oak reverse w/minnkota cruise control
| Tue Mar 30, 2010 11:19 am |
TinySack
 Re: my lower bearing on my mudbuddy
got it figured the play in the bearing in from1/16th to 1/8 inch which that is fine being its a water cooled bearing they tend to heat up and let a little grease out so bearing is good and if the seals are out ill be out only 30 bucks. maybe this will help others out as well
| Tue Mar 30, 2010 1:13 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
careful with that tiny. i had a bearing go bad on my old 31 sport. that bad bearing ended up scoring the shaft. i had a local dealer just send the lower to mudbuddy to get rebuilt. seals, bearings, shaft and freight totaled right at $500.
_________________ 1850 & 36pd
| Thu Apr 01, 2010 1:38 am |
deadbird8
I posted pics of re-doing the seal/race on the MB forum.
Like Med said- a cheap fix for that rear seal and race (do both of them at the same time) so you don't loose bearings or your shaft.
| Fri Apr 02, 2010 8:15 pm |
TinySack
thanks for the help got it fixed
| Tue May 04, 2010 11:59 am |
[ 5 posts ] |
