It is currently Sat Jun 28, 2025 3:01 am
[ 6 posts ] |
jus10inla
Joined: Tue Jan 13, 2009 5:55 pm Posts: 1636 Location: Baton Rouge, LA (Central)
 relays for trim
on GT, there is a relay to the trim. could i also use that relay to add an extra trim to a grab bar?
i know drake1 has an extra trim switch on his motor. it should work off the same principle, correct?
Mon Apr 19, 2010 9:18 pm |
craig
 Re: relays for trim
Just run your wires straight to the original trim toggle switch.
Mon Apr 19, 2010 9:24 pm |
jus10inla
 Re: relays for trim
i thought about that. but then i would have to run at least #8.. it would look alot cleaner runnin #14 to a relay tho?
Mon Apr 19, 2010 9:27 pm |
craig
 Re: relays for trim
I just used the wires that come with the switch. Ran it from my handle to the original trim toggle and just spliced it there.
Mon Apr 19, 2010 9:36 pm |
jus10inla
 Re: relays for trim
what size wire is run to your original trim? if im not mistaken on the GT there is a relay betwen the battery and trim.. thus allowing the smaller wire to the back of the original trim. there is no relay on the PD, it looks like #8 from the battery to the original trim switch.
Mon Apr 19, 2010 11:01 pm |
Tulsa_Woody
Joined: Wed Jan 14, 2009 8:31 am Posts: 428 Location: Tulsa, OK...Cajun by Marriage
 Re: relays for trim
_________________ 17x54 Gator-Tail w/ 35HP GTR Gator-tail/MM exhaust Center Console...it fixes tiller torque viewtopic.php?f=4&t=9330
Tue Apr 20, 2010 5:56 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 56 guests |
