relays for trim http://mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=9197 |
Author: | jus10inla [ Mon Apr 19, 2010 9:18 pm ] |
Post subject: | relays for trim |
on GT, there is a relay to the trim. could i also use that relay to add an extra trim to a grab bar? i know drake1 has an extra trim switch on his motor. it should work off the same principle, correct? |
Author: | craig [ Mon Apr 19, 2010 9:24 pm ] |
Post subject: | Re: relays for trim |
Just run your wires straight to the original trim toggle switch. |
Author: | jus10inla [ Mon Apr 19, 2010 9:27 pm ] |
i thought about that. but then i would have to run at least #8.. it would look alot cleaner runnin #14 to a relay tho? |
Author: | craig [ Mon Apr 19, 2010 9:36 pm ] |
I just used the wires that come with the switch. Ran it from my handle to the original trim toggle and just spliced it there. |
Author: | jus10inla [ Mon Apr 19, 2010 11:01 pm ] |
what size wire is run to your original trim? if im not mistaken on the GT there is a relay betwen the battery and trim.. thus allowing the smaller wire to the back of the original trim. there is no relay on the PD, it looks like #8 from the battery to the original trim switch. |
Author: | Tulsa_Woody [ Tue Apr 20, 2010 5:56 am ] |
viewtopic.php?f=2&t=6324&hilit=trim+switch Woody |
