It is currently Sun Nov 16, 2025 12:04 am
Reply to topic  [ 6 posts ]
 relays for trim
Post relays for trim
on GT, there is a relay to the trim. could i also use that relay to add an extra trim to a grab bar?
i know drake1 has an extra trim switch on his motor. it should work off the same principle, correct?
Mon Apr 19, 2010 9:18 pm
Profile YIM WWW
Post Re: relays for trim
Just run your wires straight to the original trim toggle switch.
Mon Apr 19, 2010 9:24 pm
i thought about that. but then i would have to run at least #8.. it would look alot cleaner runnin #14 to a relay tho?
Mon Apr 19, 2010 9:27 pm
Profile YIM WWW
I just used the wires that come with the switch. Ran it from my handle to the original trim toggle and just spliced it there.
Mon Apr 19, 2010 9:36 pm
what size wire is run to your original trim? if im not mistaken on the GT there is a relay betwen the battery and trim.. thus allowing the smaller wire to the back of the original trim. there is no relay on the PD, it looks like #8 from the battery to the original trim switch.
Mon Apr 19, 2010 11:01 pm
Profile YIM WWW
viewtopic.php?f=2&t=6324&hilit=trim+switch
Woody
17x54 Gator-Tail w/ 35HP GTR
Gator-tail/MM exhaust
Center Console...it fixes tiller torque
viewtopic.php?f=4&t=9330
Tue Apr 20, 2010 5:56 am
