It is currently Sat Jun 21, 2025 10:19 pm
[ 4 posts ] |
flyerfly
Joined: Fri Feb 18, 2011 12:06 am Posts: 24 Location: Alaska
 18x60 or 20x54 GD?
Hello,
Is there anyone that has a 20x54 GD SD boat that could give a report or numbers on it with the 35HP SD GD? I am trying to decide between the 18x60 and the 20x54 go devil. I already read about the 18x60 but have not seen any reports about the 20x54.
I will be mostly running rivers (Alaska). Silt on the large rivers and logs on the small ones. The small rivers are very crooked and I wonder if the 20x54 would be harder to turn fast. Also I would love to know what water depth the 20x54 can go in compared to the 18x60.
Thanks for any feedback.
Fri Feb 18, 2011 2:07 am |
TURBODRIVE
 Re: 18x60 or 20x54 GD?
I would go with the lighter/smaller boat.
when loaded down you need all you can get outta the 35
Fri Feb 18, 2011 3:15 am |
Gigafowl
I would spend some time on a call to the factory and talk with Coco... If you call on most any business day he is there and loves to talk about boats...
From what I know about the GD 54 wide - the bottom profile and taper are the same as the GD 60 wide - they press them out of the same width blank sheet and the 54 is 6" narrower so it can have 3" higher sides....
Since actual "footprint" in the water is virtually the same on the 2 sizes load carry should be very comparable - but I would tend to think that the longer narrower hull would turn better at WOT - but only slightly better since the point of contact or taper is identical....
PS - you might PM MMT member STUALASKA - he is up your way and I have enjoyed his posts on the treks he takes in Alaska
Good Luck and welcome to MMT
Fri Feb 18, 2011 7:54 am |
flyerfly
Does anyone on the forum have a 20x54 GD?
Sat Feb 19, 2011 12:13 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 55 guests |
