It is currently Tue Jun 24, 2025 4:12 pm
Reply to topic  [ 14 posts ]
 copperhead 18HP on 1648
Post copperhead 18HP on 1648
just ran my new copperhead 18Hp on my 1648 all weld and wow i was really amazed . with me and one person and a full ice chest i was getting 22 mph and by myself i was getting 24 mph.
18 HP copperhead.
Mon Oct 03, 2011 7:44 pm
Post Re: copperhead 18HP on 1648
nice, did u get the kohler or brigg's ,your going to have fun with that set up, how about the low end torque there great i have the kohler good luck ;)
Life is like rolling the Dice
Tue Oct 04, 2011 3:39 am
That is impressive! I was looking on the Copperhead site and they don't even list an 18 HP. That is a good development. What is the weight on that puppy? I presently have a 1648 with a 27 MB longtail and that 18 already tops my top end speed. I would prefer a simple balanced drive with no clutch. What kind of conditions are you running in? We have mostly weeds no real mud and hard bottom. Please advise.
Tue Oct 04, 2011 6:17 am
The 18 briggs weighs 135# its super light and i couldnt be happier with it. I was really impressed with the speeds i was getting because of how big my boat is but it preformed awesome. I plan on putting the film on Youtube in the next couple of days i will post a link when i get it done. We running the boat thru lilly pads in about a foot of water, it actully runs faster thru the lillys than it does in open water.
18 HP copperhead.
Tue Oct 04, 2011 8:21 pm
Is that on a .125 gauge hull?
Wed Oct 05, 2011 3:08 pm
no
Wed Oct 05, 2011 3:39 pm
you could run .125 gauge will be a little slower but still get the job done ;) my phowler 15/40 .100 /5086 stiffer than 5052 with the 18hp great set up
Wed Oct 05, 2011 5:45 pm
Tremendous numbers on the 18! If and when Copperhead tries out a 23 HP, that would really be cool. That just might be the ticket! I like the marketplace and competition usually produces gains to the mud motor consumer.
Fri Oct 07, 2011 3:52 am
Sun Oct 09, 2011 10:11 am
If you wanted it bad enough, a 23 and 18 have the same bolt patterns and crank specs.
Personally, I would mod the 18.
Sun Oct 09, 2011 10:30 am
Sun Oct 09, 2011 11:25 am
The 18 and 23 are identical blocks, the 18 has a slightly shorter stroke and a few different parts (carbs, cams, ect.)
The wieght of the two are nearly identical, the only problems there could be is if the frame has the strength for the extra torque of a 23. You would also need to change gear ratios to get optimum performance.
Sun Oct 09, 2011 11:40 am
how could i mod the 18 hp to get more out of it.
18 HP copperhead.
Sun Oct 09, 2011 11:50 pm
I'd leave it alone, don't wanna go too fast in dry prong :D
Start with an exhaust, then heads, then fool with a carb or cam.
Mon Oct 10, 2011 7:52 am
Users browsing this forum: No registered users and 59 guests
