It is currently Sat Jul 04, 2026 12:35 am
Reply to topic  [ 19 posts ]
 15/48 weldbuilt 27mini
Post 15/48 weldbuilt 27mini
This is a flat bottom boat (not smooth) with a mod front,I bought a bare hull and put in a floor ,fishing deck and gun boxs. I beefed up the transom and installed a cmc power trim unit, i have a trim switch at the rear and on the grab bar (its sweet). The boat weighs 450 lbs bare weight .The 27 mini weighs 208. I have a 9 gal tank up under the deck and the battery is in the center bench.
With two average size guys and a cooler it will run a steady 21.8 in deep water.Its a great all around rig .There is one thing I dont like about the mini,and that is the turn radius , is will only cut about 45 degrees to the transome where as the GD i had would cut right up to the transom.the motor would no doubt perform better on a mud hull ,but cost vs performance....... Well I think she will get the job done.
off the streets and on the creeks
15/42 crawdad 23 swomp
Mon Aug 03, 2009 8:31 pm
Post Re: 15/48 weldbuilt 27mini
Mon Aug 03, 2009 8:32 pm
nice looking boat man !!1
Mon Aug 03, 2009 8:37 pm
Profile YIM
looks like ur well setup, i like the inside bro, everything has its place. very nice build.
Tue Aug 04, 2009 1:38 pm
MMT Moderator
grab bar doesnt seem like its in a comfy spot or a safe one
duck wacker
Wed Aug 05, 2009 9:56 pm
Looks good but the shark eye nav lights look backwards to me.
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Thu Aug 06, 2009 6:07 am
Thu Aug 06, 2009 7:12 am
Thu Aug 06, 2009 7:15 am
It works pretty well about the best thing i could come up with
Thu Aug 06, 2009 8:01 am
where did you get that jack plate?
Fri Aug 07, 2009 9:50 am
Fri Aug 07, 2009 5:44 pm
Sat Aug 08, 2009 11:32 am
Sun Aug 09, 2009 9:40 pm
The GW is gonna jack you up about those light not being seen from the front.[/quote]
I talked to a wood county G W this morning and yes indeed if the bow lights are not visible from front he'll slap one on ya
Tue Aug 11, 2009 11:29 am
Glad you herd it from the horses mouth. I was just trying to keep you from gettin a ticket. If you turn the lights around you will be fine.
Tue Aug 11, 2009 3:12 pm
Man that motors a Beast on that boat... What Gauge Alum. is ur boat...?
Thu Aug 05, 2010 9:50 am
Is this a semi - v style boat. I know you mention is is flat... I was under the impression that you couldn't run a surface drive with a semi-v?
I've got an Xpress DB VX15 with a tiller but would like to switch to a surface drive...
Sun Aug 29, 2010 6:01 pm
You can run a sd on a mod V boat. just like running your out board
1748 pd boat w/ 36pd hht & fpr
Fri Sep 03, 2010 10:50 am
I really like that boat, I would love to have one with a 40 or 50 hp tiller outboard on it for runnin the river here where a mud motor is not needed.
Fri Sep 03, 2010 11:05 am
