1848 Custom Phowler Extreme w/Stage 1 36 PD
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=1222
Author:  willett [ Mon Mar 23, 2009 12:31 pm ]
Post subject:  1848 Custom Phowler Extreme w/Stage 1 36 PD
First off i have to thank Phowler (PW and Susan) and cuttdown for all the help and for making this deal right! Once I made the decision for them to build another boat and we talked about everyting I wanted different they got the boat done in little over 2 weeks time! MitchV was comin down to Ft. Hood to see his son and volunteered to bring the new boat down to me. I met Mitch on Thursday (March 19) and made the swap. Thanks alot Mitch for volunteering and helping me out and God Bless your son for his services!
Motor: 36 Pro Drive with EVT Stage 1 Kit
Boat:
Custom built 1848 Phowler Extreme - No Floatation
6 - 2x2 Longitudinal Runners - All Welded to Transom
4 - 2x2 Cross Braces
Tall Transom
20" Sides
Extended Deck
Pointed Bow
SPUD Pole Kit
2 Rear Half Boxes
Movable Gun Box
Pipe in Pointed bow for Front SPUD pole and also for other accessories such as winch, lights, etc.
Flat Black Base coat with RealFoot Camo Paint on outside and inside on sides but gonna put hydroturf down on floor and deck so told them no point in paintin that
Speeds:
First Run out All deep water - battery in rear and full tank of gas in front running a 12x13 Tulip prop that has some wear from sand
Me (160) and the fiance (110) in the back hit 29 an bow started bouncin
Moved her to middle of the gun box and hit 31 for a second but bow still wanted to bounce - Then buddy of mine (200+) got in and had him sit on the gun box and ran 28 most of the time into the wind...as the gas ran down the bow wanted to start to bouncin again
It felt like I was goin alot faster then what the GPS showed and with some tweaking of the trim tabs and different prop I'm sure it'll run great!
Either way I'm extremely happy with the way the boat turned out and dont plan on gettin rid of it!
Author:  BROOKS [ Mon Mar 23, 2009 12:50 pm ]
Post subject:  Re: 1848 Custom Phowler Extreme w/Stage 1 36 PD
In mines opinion ~ I would call it the Powler Super Extreme !!! :D
I gots to see this boathull in person ..... she is diffently built stout !! Gots them 2x2's runnin' from the transom all the way up the rake to the bow ..... six times pinned down four times !!!! Wow !!!! Very well built to say the least !!!
Willett ~ ...... Git a new trailer !!!! Mabe one of them shinny aluminum ones and be a real "Stud" !!!!!! :lol:
Proud fo ya !! and Job well done .... MudDoctors !!!!! :D
Author:  LaBirdman [ Mon Mar 23, 2009 3:51 pm ]
One fine looking boat there Will. Phowler did you right and one hell of a deal. Hope she treats you right and not like the first one.
Author:  mudgrappler [ Mon Mar 23, 2009 6:44 pm ]
Like I told you yesterday, damn good looking rig and it appears to be built for the long haul. Im sure once you play with them trim tabs you'll be running 30 all day with a light load.
Author:  muddoctor [ Wed Mar 25, 2009 10:41 am ]
Hey Willett, glad you like the replacement boat, I hope we exceeded your expectation. Sounds like she is running good, adjust the trim tabs down a bit. You might also be dealing with some proposing from the clever prop, we have seen this on a number of modds set-ups, to much lift from the prop seems to cause this issue right at the 30mph mark. Modified stock PD props seem to eliminate this issue. Play with it and see what works.
I got a chance to look at your old boat first hand this morning and I believe my first assessment was correct, the memory in the hull is what is causing the crowning, it surely did not look anything like that when it left here. I don't see anything that would lead me to believe the few impact marks on the bottom would have caused this issue, the crown is uniform down the center of the boat, if you look close you can actually see the natural curve to the crown, this is from a hull that was over bent from our sheet supplier and then was pushed back out and bottom pushed back down by TMT. It was only a mater of time before the hull memory started pushing the bottom back up. We are sorry for the inconvience this caused you and hope we have made things right by you with your replacement boat.
Now go have some fun with your new rig.
Paul Willging
Author:  willett [ Wed Mar 25, 2009 11:20 am ]
I absolutely love the new boat...it came out better than I imagined
I was running a modified stock prop (pitched to 13) when it was bouncing so gonna do some adjustments and run couple different props but either way I'm happy with everything on it! Thanks for the help
Author:  River [ Wed Mar 25, 2009 11:20 am ]
Willeyyyy
glad your new boat is the shizzle.
I am unclear as to how prop lift will cause a boat to porpoise. It is doing the same thing as a trim tab, lifting the back of the boat so as to keep the front down.
trim tab or wedges is the only option I can see. not a big deal.
Author:  muddoctor [ Wed Mar 25, 2009 2:10 pm ]
I am not sure why this is, just know I have heard about it more then a few times with guys playing with different props on a variety of hull (GT, PD, Go-Devil, Excels, etc). The clever prop is an aggressive lifting prop from what I have been told. I do know when the 36 came out PD had issues with the clevers working the way they wanted them to, one reason they went to the mod tulip. Again, I am not a prop FE, I just know what I have seen and been told and what I have seen on a few rigs we tested props on.
I could be all wrong on that one, there are alot of guys out there with alot more prop wrenching time under their belts then me.
In Willetts case I would say if he is running a Mod Tulip already, I would adjust trim tabs first, then look at a 13.5 or even a 14 pitch.
PW
Author:  50fps [ Wed Mar 25, 2009 9:07 pm ]
Nice to see it all together.
I do have to say that the way this hull is put together it should hold up very well, the bracing is almost overkill when compared to other hulls.
And thanks for making the swap go smoothly.
Author:  muddoctor [ Thu Mar 26, 2009 11:25 am ]
Mitch,
Thanks for your help in getting Willett his boat, it worked out really great that we could get it down so quickly.
I owe you one.
PW
Author:  willett [ Thu Mar 26, 2009 11:37 am ]
yea thanks again paul for your guys hard work and quick turn around and mitch for bringing it hope your son is well
Author:  cash [ Thu Mar 26, 2009 12:51 pm ]
Good looking rig Willet!
Looks pretty sturdy!
Author:  Mudgun [ Thu Mar 26, 2009 1:22 pm ]
Can't ask for any more than that!
Good looking rig. Impressive service by the dealer/manufacturer. Does not go unnoticed.
Author:  pouldeau [ Thu Mar 26, 2009 5:42 pm ]
That's one fine looking rig. I like it!
Sounds like a good bunch of fellas. Hat's off to all involved.
Author:  Crews [ Mon Mar 30, 2009 7:27 am ]
I got to see this boat yesterday, and I really liked the way they carried the 2x2 runners all the way up the rake.
Author:  basinhunter [ Mon Mar 30, 2009 7:54 am ]
Author:  muddoctor [ Mon Mar 30, 2009 8:00 am ]
Thank you all for the comments on the boat. We always carry the runners up the rake, that is where they take most of the abuse. We built Willetts boat custom to his specs. Frankly the 2X2 runners with the heavy cross bracing is overkill. We have never had issues the 1X2 runners not holding up under abuse, just look at our demo videos and the hundreds of our, and other boats out there using 1X2 stringers. Willett's was an unusual case with the way the hull was bent and then built, no excuses here, it was not done the way we would have accepted, so we replaced it. But after his inconvience we felt we should get his replacement to him as quickly at possible and build it the way he wanted it done to ensure there was no chance of issues with the hull long term. So let just call it the Phowler Series EXXXTREME - "Willett Special".
Paul Willging
Author:  willett [ Mon Mar 30, 2009 8:13 am ]
nice...call it the "Willett Edition"
Author:  willett [ Mon Mar 30, 2009 8:15 am ]
Got hydroturf in the floor and in the boxes yesterday and looks awesome waitin on one BIG sheet to get here today and will put it on the deck then post some more pics
Author:  westwind [ Mon Mar 30, 2009 9:26 am ]
Nice boat. Like it that the runners tie into the transom, that is built for stout.
Author:  willett [ Mon Mar 30, 2009 10:59 am ]
Yea thats one extra thing I personally wanted...gatortrax is the only builder who runs their runners all the way to the transom and weld them to the transom for extra support and ever since I noticed that I wanted that done to my boat
Author:  craig [ Mon Mar 30, 2009 11:18 am ]
Author:  willett [ Mon Mar 30, 2009 8:16 pm ]
wow guess i've never looked at a GD boat that close but thats good for them!
Author:  stumpgrinder [ Tue Mar 31, 2009 8:17 pm ]
Author:  MaXXis85 [ Wed Apr 01, 2009 7:22 am ]
If your boat is custom, the builder will build it how you want it. Anyways nice rig willet.
Author:  DuckHunter [ Tue Apr 14, 2009 4:37 pm ]
Nice looking boat you got there
