jmjohnson0331
Gator-Tail vs. Pro drive
Im looking into buying a new motor and I really want reverse I like the Gator-tail but i dont know how powerful their reverse and i believe that the prodrive is full power but i do not know I would just like more power to pull me off of bogs and such that i cant get off of going forward easily, can i Just get some opinions and pros and cons of each motor or people who have one tell me a little about them...... Thanks
Tue Mar 01, 2011 11:15 pm |
eljefe
Joined: Thu Jan 13, 2011 7:32 am Posts: 5210 Location: Beaumont Texas
Re: Gator-Tail vs. Pro drive
Pd Full power reverse gtr less pull in reverse
Id go testdrive them and make your own decision.
_________________ You can't see the sunrise if your eyes are closed. dying aint much of a livin....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com fuel injected 25 GTR
Tue Mar 01, 2011 11:29 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
All depends on what you plan on doing with it. Also, were your gonna be running it can make a difference in what you'll need.
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Tue Mar 01, 2011 11:42 pm |
jmjohnson0331
I hunt marshes with hardley any water and i go to big water somethimes as well but they should both handle mud well i would assume right?
Wed Mar 02, 2011 7:42 am |
petrel
Joined: Mon Jan 11, 2010 9:51 am Posts: 770 Location: NVA
I'm a new ProDrive owner and went through that decision last fall. To me, there were two considerations: Do I need instantaneous reverse? Do I need full power in reverse. My answers were no and yes, so I went with a prodrive. It takes 5-7 seconds for a PD to cycle into reverse. The GTR is instantaneous. I hunt tidal marshes, so I end up in situations where the tide goes out under my boat. The full power reverse drags the boat off of the bank in short order and can also back out of difficult situations like creeks and guts too narrow to turn around in.
With regard to their performance in the mud, mine does everything I expect from it and then some. However, that is a point of great contention on this site. It will make for a very amusing read if you take the time to catch up on that topic!
I spoke to both manufacturers at length before I made my purchase. They are both easy to contact, great to work with, build a quality product, and stand behind it. So long as you pick the right one for YOUR needs, you can't go wrong either way.
_________________ Phowler 2066 w/ E5 37 ProDrive w/ Illowa Marine Heads MoMarsh Fatboy/2 Honda
Wed Mar 02, 2011 8:04 am |
WestEndAngler
MMT Moderator
The main difference (IN MY AREA) I see besides the PD having full power reverse is that the Gator-Tail can trim down MUCH further than the PD allowing you to get out easier & faster.
Pros & Cons to any motor go test drive them ALL
Wed Mar 02, 2011 8:21 am |
quackconsumer
Anyone who answers dis queation wit an answer other than go test drive dem both. Will be nailed to a willow tree by da nuts and bitch slapped by all at da next run.
Wed Mar 02, 2011 8:28 am |
WestEndAngler
MMT Moderator
Wed Mar 02, 2011 8:44 am |
craig
Wed Mar 02, 2011 12:22 pm |
quackconsumer
Wed Mar 02, 2011 12:31 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
go test drive them all...........am i safe
Wed Mar 02, 2011 12:34 pm |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
If you don't have a chance to run both. The gatortail in thicker mud will have a slight advantage over a PD. Gatortail will also have more tiller torque due to the longer shaft so long runs can be more of a challenge for some. Instant reverse is nice. PD is easier run, and FPR will pull you off Bogs No Problem. The lower unit design is a better match for open water and big Water.
_________________ If I can't Break it, it can't be Broke.............................
Sat Mar 05, 2011 12:46 am |
JIMMY W
GatorTail is also a little faster
Sat Mar 05, 2011 4:51 am |
quackconsumer
I'm gonna need more nails.
Sat Mar 05, 2011 7:35 am |
WestEndAngler
MMT Moderator
Sat Mar 05, 2011 7:44 am |
eljefe
If I were you Id jump on turbodrives prodrive he has for sale.
Sat Mar 05, 2011 8:18 am |
POKER1
I fish alot and that instant reverse would be nice when running lines. The GT can get lower in that thick mud you see folks running at the mud runs. But in reality how often would you get your rig into that situation unless you were trying to. Depends on the areas you run but I bet you could avoid it most of the time. We dont have anything like that around here. Either one will probably do everything you need it to and then some. They will all get you stuck like a mofo if your not careful.
Sat Mar 05, 2011 11:27 am |
Woodiebuster
A pro drive with fpr and instant reverse would be perfect around here.
You need to decide wether you want reverse for convienence or full function
Sat Mar 05, 2011 11:43 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
Go run them both as people said...
Gatortails are great in forward and in mud
Prodrives are great in forward and ok in the mud untill you stop..
As said the prodrive will not dig as deep as a gatortail in mud.
I find that the reverse for the prodrive in better in thick vegetation. In different mud conditions the prodrive reverse will not do much though.
The gatortail reverse can be buried down in the mud to dig a hole although I find that when in thick vegetation its not as helpful as the prodrive full power.
PS I have nothing against gatortail. Its all about what you need and the terrain you run.
_________________ I gave up mud motors
Sat Mar 05, 2011 1:30 pm |
quackconsumer
I hope der's gonna be enough willow trees.
Sat Mar 05, 2011 2:19 pm |
T-Bubba
Sat Mar 05, 2011 2:25 pm |
XGEN-DUCKMAN
Sun Mar 06, 2011 6:34 am |
XGEN-DUCKMAN
Sorry just realized this is the wrong forum.......reviews only ....I should know better
Sun Mar 06, 2011 8:22 am |
austinabear
Joined: Tue Mar 15, 2011 11:15 pm Posts: 238 Location: Port Neches, SETX
One thing I like about the reverse of a Prodrive is that if you ever get too shallow and can't get up, you can dig you a hole forwards and backwards long enough for you to hop up back on top of the mud..
Thu Apr 21, 2011 4:04 pm |
TURBODRIVE
i bet Terry's so messed up reading this he caint type cuase he's shaking, just wait his shakes will go away shortly
Thu Apr 21, 2011 4:12 pm |
337prodrivin
Joined: Wed Feb 09, 2011 12:40 pm Posts: 7 Location: New Iberia, La
I did my research I drove and rode in both. I like the instant rever and the gator tail handles better but the reverse sucks ass even in deep water. The prodrive has more torque but got the fpr for when you need to get it. Also like the momentary button on my prodrive and the twist throttle doesnt have a cable to freeze up.
_________________ 36PD FPR on 1648PD X series hull...EATIN GTRs!!
Thu Apr 21, 2011 5:03 pm |
oncall
Joined: Mon May 10, 2010 1:46 pm Posts: 1180 Location: Georgia
Is your signature suppose to be chasin??
_________________ 1854 Brother pulling a 36 PD viewtopic.php?f=5&t=12825 Brooks: "Tries masterbation and thank happy thots ...... purt near pulled mines off when I quit 'em ....."
Thu Apr 21, 2011 9:13 pm |
meterman3
quack wrote ,I hope der's gonna be enough willow trees.
ya better get some bigger nails
_________________ driving a gd in ur lake and i aprove this message
Thu Apr 21, 2011 10:03 pm |
JIMMY W
Fri Apr 22, 2011 7:01 pm |
muddoctor
I agree with most of what has been said so far, the GT reverse works, but it pull just like an outboard reverse, 40% of the power in reverse vs. forward. It will pull you back in soft, really soft mud, but up here over semi hard bottom, heavy weeds or hard bottom it does nothing without 12" of water or more. Second in the really nasty stuff leading with the prop you can damage it, we have seen 4-5 with twisted shafts from backing into a stump in reverse. Again, they make a great conventional reverse, but that is what it is, a conventional reverse.
On the other side of the coin the PD reverse has the power to lift the enter boat and put all the water under the boat, it leads with the skeg so we do not see them damaged from use in the wood. Down side it is slower to use, but the new auto makes it alot easier then the manual option. I think it does alot better in the really nasty stuff and frankly I have not seen a situation the GT can get out of that the PD did not get out of faster in reverse, but I have see many situations the GT reverse did nothing and the PD reverse walked right out of. For real hunting conditions in our neck of the woods the PD has it hands down. The GT is a bit faster, the PD handles easier.
This is what I have witnessed running both extensively and one the water with my rig and some of my buddies rigs in real hunting situations.
As said, don't take anyones word as gossip, try to run them both yourself and them form your own opinion of which one will be meet your needs in your situation.
PW
_________________ Paul V. Willging - Owner Phowler Boat Company Illowa Marine
1701 Main Avenue, Clinton, Iowa 52732 563-242-8969 or cell 563-212-7091 email: larrys-prodrive@mchsi.com
Tue Apr 26, 2011 6:36 pm |
deltaduckmaster
Tue Apr 26, 2011 7:11 pm |
robertb4wd
Joined: Sat Jul 18, 2009 7:18 pm Posts: 1501 Location: Bridge City, Texas
Wow, calm down DDM. Get one of those MIDOL's from take'em..
_________________ 1754 Gatortail Extreme / 35 GTR
Tue Apr 26, 2011 7:23 pm |
deltaduckmaster
I really can't stand this forken dude!! The one thing he said and think about it!! He said in hard bottom Pd rules and a gt needs 12 inches of water!! Everybody on mmt knows that in hard bottoms the worst motor out their is the Pd because of the oversized lower unit!! Please feel free to chime in on this one!!
Tue Apr 26, 2011 7:28 pm |
robertb4wd
Hard bottom sucks if your trying to get on step. From what I've seen, it's like the PD's take a while to bite in shallow water while the others tend to go. Where I hunt / ride, you need to get moving to get up. When you can't grab a little, you sit there a while.
Tue Apr 26, 2011 7:34 pm |
OwenDickeson
Tue Apr 26, 2011 7:52 pm |
deltaduckmaster
Owen the harder the bottom the better a gt reverse works !! 12 inces of water a outboard is all you need!!
Tue Apr 26, 2011 8:07 pm |
take'emgator
Wheeew shiat......i'm gonna go out on a limb here but i have to agree with Terry, I can walk my lower unit across the top of a hard bottom and back the boat up pretty good if i can say so myself, there are tricks
Tue Apr 26, 2011 8:37 pm |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Tue Apr 26, 2011 8:39 pm |
meterman3
damn he was just helpin answer a question pros and cons of both yeah i drive a pd ddm before ya get yer feathers up been in one of yer holyer than now gtr nice motor faster better than in the mud than my pd great reverse up to about 40% lol but for MY HARD SANDY BOTTOM the pd will eat sand better IMHO. and yes ddm dont have as much tiller time or yer gift with a mm , but mine works for me thanks yall
Tue Apr 26, 2011 8:46 pm |
garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
about ten guys and myself had this same argument lastnight. i have a gtr and in hard bottom there is nothing but a go-devil long tail that will get up in shallower water then me. i have seen plenty of prodrives stuck in real hard bottom i.e. the delta. the only time i see a pd is better if you have a ditch 4' wide with high banks on each side full of packed lillies and you can turn the motor around and back up but thats about it.
Tue Apr 26, 2011 8:49 pm |
