Sand on surface drive http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=19729 |
Author: | jellyhead22 [ Mon Jul 04, 2011 10:34 am ] |
Post subject: | Sand on surface drive |
I was just curious if sand is really bad on a surface drive mm? |
Author: | Team Camo [ Mon Jul 04, 2011 10:40 am ] |
Post subject: | Re: Sand on surface drive |
Seriously? If you run sand, you're gonna burn thru some props. If you hit a sand bar, it's probably gonna land you on your azz in the front of the boat when it comes to the abrupt stop. Other than that, I can't think if anything else it'll hurt just by passing thru it. Sent from my Droid because I'm trying to be as cool as you someday. |
Author: | quackconsumer [ Mon Jul 04, 2011 11:24 am ] |
Mix about 1/4 cup of sand with your engine oil and your mm will be able to run through sand like a chainsaw through butter. |
Author: | locked-up [ Mon Jul 04, 2011 1:07 pm ] |
I run lots of sand and gravel with a Prodrive rock guard. You can't run as shallow but it will go just fine as long as you got at least 8" of water. Get a rock guard so you don't push your prop into the sand it will go good. |
