what boat should i be looking at http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=22781 |
Author: | leatherwood [ Mon Oct 03, 2011 8:27 pm ] |
Post subject: | what boat should i be looking at |
I have a 2011 23 vanguard mb mini and am looking for a 15ft boat or so, any one else run this motor on a boat and like your set up, just wanting to get some input,thanx. |
Author: | Migrator [ Mon Oct 03, 2011 8:32 pm ] |
Post subject: | Re: what boat should i be looking at |
What are you wanting to do w/ your rig. What type areas will you be running. |
Author: | leatherwood [ Mon Oct 03, 2011 8:36 pm ] |
Mostly just duck hunting maybe try to get into bow fishing. The area I mostly run is around 5 inches on a low day and is pretty soft but I do run bay front a lot which is really hard also. I was thinking about just going with open floor plan and deck infront on a 15ft flat bottom alweld, bad idea you think? |
Author: | UNCLE-J [ Mon Oct 03, 2011 8:44 pm ] |
That's a easy question.. A Uncle J Custom Hull.. Built the way YOU want it. www.unclejcustomboats.com With Love, Uncle J |
Author: | mcnemar1982 [ Mon Oct 03, 2011 8:47 pm ] |
Author: | Migrator [ Mon Oct 03, 2011 8:49 pm ] |
Are you running marsh and open areas? This will affect my answer. There are a lot of custom builders on here that can hook you up. I like my G-trax for what I do but alot of the coastal guys are running hard chined boats and really like them also. |
Author: | leatherwood [ Mon Oct 03, 2011 8:53 pm ] |
Yea a lot of marsh areas |
Author: | Migrator [ Mon Oct 03, 2011 9:08 pm ] |
I was thinking like barnes. The rogue that G-trax makes would run good w/ that motor. If price is big factor you may check w/ some of the builders on this site and get just what you want and not spend much more than you would on the alweld and have a lot more boat. |
Author: | ST [ Tue Oct 04, 2011 2:16 pm ] |
Check this one out. Seems like it would be perfect for a 23hp. I have seen it and it is built like a tank. Looks like the price is right also. viewtopic.php?f=62&t=22532 |
Author: | JIMMY W [ Tue Oct 04, 2011 5:19 pm ] |
Uncle J built one for one of my hunting buddies and it really is a 1st class job!Really came out great! |
Author: | Crews [ Tue Oct 04, 2011 6:04 pm ] |
16 foot, 48 at the widest, 36 at the narrowest. Square or tapered chine, with not a lot of extra boxes or weight. I used to have a 23 way back in the day, it ran great on a 16x36 Godevil round chine boat. Would have done better on a tapered chine boat. In fact, a 16x42 would have been perfect. |
Author: | Team Camo [ Wed Oct 05, 2011 9:26 pm ] |
leatherwood, correct me if I'm wrong, but aren't you from here? Reason I ask is because several guys running 23's around here, best one I've seen so far has carb & exhaust & is running a 17/48 Weldbilt. Hauls azz for a 23 & carries a pretty decent load too. If you're local, I could set you up with a test ride. |
Author: | smash [ Thu Oct 06, 2011 9:19 am ] |
Author: | UNCLE-J [ Thu Oct 06, 2011 11:36 am ] |
Author: | leatherwood [ Sat Oct 08, 2011 6:16 pm ] |
Team camo, yes I am from around here. Crosby texas to be exact. I just bought a used 1644 go devil slick bottom boat for my 23, haven't had a chance to run it yet, I know it won't win a race but I like the room and it should get the job done and if it doesn't I might upgrade to a man size motor next season. I paid 2800 for boat and trailer its a 2000 model boat. Was that a good deal? I will post how it runs maybe tomorrrow. |
Author: | Team Camo [ Sat Oct 08, 2011 6:36 pm ] |
I think $2k was a fair deal, & with a lil work & $, that 23 will push you pretty good. If you decide you still want more, that hull will handle a 35, no sweat. |
Author: | leatherwood [ Sat Oct 08, 2011 7:31 pm ] |
What do you suggest I should throw on that motor to get a little more hop to my jump and how much. Thanx for any input |
Author: | Team Camo [ Sat Oct 08, 2011 8:01 pm ] |
Try the usual bolt on parts (carb, heads & exhaust) & see how she does. I wouldn't go too much further than that with a Mini, tho. |
Author: | Sko [ Sat Oct 08, 2011 8:31 pm ] |
The boat build beg off. Lol |
