weldbuilt boats
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=23448
Author:  mucknaked [ Wed Oct 26, 2011 5:28 am ]
Post subject:  weldbuilt boats
what about weldbuilt boats? are they any good?
Author:  Gigafowl [ Wed Oct 26, 2011 7:29 am ]
Post subject:  Re: weldbuilt boats
Very capable - very light and fast
Cross bracing is not ideal - allows some denting between braces - but I really
liked mine - just not as tough as a GD or other hull with longitudinal braces
Author:  OwenDickeson [ Wed Oct 26, 2011 7:43 am ]
It will be fin as long as your not running stumps or jumping logs and stuff.
Author:  mucknaked [ Wed Oct 26, 2011 11:05 am ]
Thank you for the up date. What size is your boats, what size motors, and how fast do they run?
Author:  Gigafowl [ Wed Oct 26, 2011 12:01 pm ]
I had a WeldBilt 17x42 with 25gdlt then a 27 gdsd
longtail would do 21mph solo - 18mph with 2 men and gear
27 gdsd would do 29mph solo - 25mph with 2 men and gear - 18mph with 3
35 gdsd - was too much for it - flexed the hull and ran spooky fast and
was unturnable at 35 plus mph - LOL
Boat was old (10 years)- light (.80 gauge 350lbs) - and fast but
slid pretty good in a fast turn due to the square chines.... Bottom
was dented between every rib - but never seemed to affect performance
just looked like heck...
I got it well used at a good price and it was a very capable and enjoyable
hull for the 2 or 3 years I ran it - carried a load very well - square nose
was a bit unforgiving in the timber was about my only negative issue....
Author:  zschne1 [ Wed Oct 26, 2011 12:19 pm ]
Not the same boat, but comparable...
I run a 16'x48'' allweld and push it with a 2005 moded out Mud Buddy. I get 29mph in a few feet of water with no wind.
We beat the SH!T out of it and it holds up fairly well all things considered. It is by no means ideal, and I wiill upgrade to a mud boat hull when i can afford it. It slides (just like all square chine boats IMO) in the turns, and does fine in the mud.
All in all the boat does what I need it to do and holds up fairly well. I did have to have the transom support re-welded (30 min and $60) after a few years of tough trailering.
I got it dirt cheap from a friend so it was the best/only option at the time for me. Not the perfect boat, but gets the job done.
Author:  Team Camo [ Wed Oct 26, 2011 2:15 pm ]
The newer Weldbilts were having a lot of problems with welds breaking. I'm not talking about guys abusing their rigs, I mean guys with outboards running clear water. Don't know if they got the issue fixed or not.
Author:  Gigafowl [ Wed Oct 26, 2011 2:54 pm ]
FTR - mine was a true mudboat with slick bottom....
Don't know how the .80 held up as well as it did - but it never leaked
a drop or had any transom issues - although I was scared to leave the
35 GDSD strapped on there - only ran it one weekend - just too much
torque - flexed it pretty bad and only about 2 feet stayed in the water
when you horsed the throttle - hull was only rated for 25 hp though in
all fairness..... Ideal for 23 to 27 hp though....
Author:  squealer [ Fri Oct 28, 2011 11:29 am ]
i have one i run a 25 HP outboard on. every weld in the front 2/3 of the boat broke within the first year. the bottom cracked in 3 places.
Author:  JIMMY W [ Sat Oct 29, 2011 7:49 pm ]
The mudmotors will tear the transom apart ;) Have done that!
Author:  SBEII Shooter [ Mon Oct 31, 2011 8:48 am ]
I bought one this year a 12x36. I put a 6hp Long Tail that I built on it. I put this together with the intention of pulling it into some remote spots we hunt with my 4 wheeler. We got serious stuck last year with the truck trying to get out at night after a walk in hunt. I hope it will allow us to get to spots on the lake easier than walking through the mud. I added an alum. diamond tread floor, 1200 GPH bilge, grab bar and 2-100 watt Explorer Pro Comp lights on a light bar I welded up. I will let you guys know how it works out.
