It is currently Wed Jun 25, 2025 4:10 pm
Reply to topic  [ 72 posts ]  Go to page 1, 2  Next
 Getting on plane
Post Getting on plane
Im having trouble getting my boat on plane. Sunday I had myself (240) and two other guys (220 and 230) and full hunting load including 6 gallons of gas, battery, 7 mojos, 2 1/2 dozen dekes, 3 guns, and blind bags. I was running in 20+ feet of water and the boat just would not get up on plane. I have a 1751 excel vf4 with a mb 35 la special.
Any suggestions on where to place everything? I have no problem getting on plane with 2 people no matter where the load is placed.
17x51 Prodigy with 37 efi hdr delta level 3
Mon Nov 28, 2011 11:49 pm
Post Re: Getting on plane
Place 1 guy,4mojos,a gun,and his blind bag on the
dock.tell him to get his own boat. :)
If ya boat has a v bottom,it prolly will never plane all that weight.
Not familiar wit mudbuddy but try trimming a bit higher than normal to bring up rpms then bump the trim back down to bite. Or go where its shallow to get up.
Tue Nov 29, 2011 1:04 am
IMHO You should have plenty of power for that load. You just need to experiment a bit with the trim and the load distribution. As the previous poster indicated, you may need to trim the motor up a bit and get some of your guests to move back a bit to let the bow get up. Once you find the right combination, you should be able to break it out easily each time.
MoMarsh Fatboy/2 Honda
Tue Nov 29, 2011 9:46 am
Tue Nov 29, 2011 11:07 am
Was the motor bogging down (not developing rpm's)? Or was the prop blowing out (max rpms/hitting the governor, and not going anywhere)?
Tue Nov 29, 2011 11:10 am
you need more motor for that load.
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Tue Nov 29, 2011 11:44 am
7 mojos....holy shit..
if you can afford that you can afford heads and cam for your motor
1848 Prodigy
35 GTR
Tue Nov 29, 2011 1:41 pm
BoatDr, the motor was bogging down. I could trim the motor way down and it would speed up for a little while but as soon as I trimmed up the rpms would get really high and the boat just wouldnt go. The fastest i went was like 15.
Tue Nov 29, 2011 4:00 pm
your prop may be worn also. I noticed a gradual decline in performance on my boat over time. It got to the point where I couldn't put three guys in the boat and get on plane. We put a new prop on and baaaaammmmmm, back to normal!
Tue Nov 29, 2011 6:14 pm
Tue Nov 29, 2011 6:19 pm
Its a brand new boat and motor. It has only been in the water 3 or 4 times so I know its not the prop. I run hard and soft bottom. It just depends on where I hunt.
Tue Nov 29, 2011 6:25 pm
It only takes 1 trip to burn a prop up. Actually about 15 min if you try hard enough
stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Tue Nov 29, 2011 6:27 pm
Put yer face in the myrtles.
Tue Nov 29, 2011 6:29 pm
I'd call your dealer (or who ever you bought it from) and try a new prop.
And yea, 15 minutes in hard/sand bottom will destroy a prop if you dont know what you are doing.
Tue Nov 29, 2011 6:31 pm
Tue Nov 29, 2011 6:34 pm
It has a tiger prop on it. I thought that was the best out there?
Tue Nov 29, 2011 6:41 pm
No props the best when you throw it to a sand bar. Just go measure it and see what your working with
Tue Nov 29, 2011 6:44 pm
Ok. I'm about to have a couple thousand dollars come my way so I'm thinking about carbs, heads, and exhaust.
Tue Nov 29, 2011 7:22 pm
Cam, heads, and exhaust.
Tue Nov 29, 2011 7:24 pm
Do you think that would be better?
Tue Nov 29, 2011 7:33 pm
That's my preference.
Tue Nov 29, 2011 7:39 pm
Tue Nov 29, 2011 8:07 pm
Tue Nov 29, 2011 8:09 pm
Tue Nov 29, 2011 8:19 pm
Tue Nov 29, 2011 8:26 pm
What would give me the most speed?
Tue Nov 29, 2011 8:31 pm
Carb, heads, exhaust, cam, pistons, rods, rocker arms and push rods.
Tue Nov 29, 2011 8:34 pm
I'm not made of money
Tue Nov 29, 2011 8:35 pm
This is what irritates me about you people. This man obviously doesn't know enough about his boat or motor to know if the performance he's getting is normal or not. You don't know what kind of boat he has, how the weight was distributed, or anything else! If it isn't doing what he thinks it should be doing, the talk automatically turns to mods. Since when is "dropping a cam in" an easy answer!!!??
24x60 Dual Prodrives
Tue Nov 29, 2011 8:36 pm
Personally i liked the Carb Kit and the heads, exhaust combination. But for that load i would go as far as to say a cam heads exhaust the works, thats an awful lot of weight for any motor, either that or upgrade to a 45mag cause your gonna need some torque to get all that moving forward and on plane, if you were running 15 thats not to bad for the weight you described
Tue Nov 29, 2011 8:37 pm
I'd do carb, heads, and exhaust.
Tue Nov 29, 2011 8:38 pm
Read his first got damn post cruise that'll automatically tell you he needs more horsepower no matter where you put the weight.....go play and let the grown ups talk.
That size boat with a stock motor should plane that load and run over 20 mph pretty easily, if you have the correct boat, you know how to drive, your motor is running right, and your prop is in good shape.
Tue Nov 29, 2011 8:39 pm
Get everybody in the boat one day after a hunt, and move them around/play with the load until you get it right. That's a lot of weight, a longer hull would def. help, my 1651 doesn't like huge loads either.
It probably wouldn't hurt to have your motor gone through and tuned up too, since it got worse over time. I bet your valves are out of adjustment by now, and that may be the cause. Mine need adjusting as we speak.
Tue Nov 29, 2011 8:41 pm
I wouldn't complain about the 15 MPH if I was planed out when I was running but when you ain't on plane and hit some hard bottom it makes for a long push to the blind.
Tue Nov 29, 2011 8:42 pm
Hell he's got 690lb's of just warm bodies, not to mention another 200+ in gear including the boat, them F-4s aren't the lightest boats.
Tue Nov 29, 2011 8:43 pm
Tue Nov 29, 2011 8:44 pm
Take your no boat owning ass over there and show him know it all lol I'm getting a kick out of this
Tue Nov 29, 2011 8:46 pm
I know it is a new motor, but you may want to do a leak down test on your heads. One of you valves may be floating, and you are losing compression, and therefore losing power. Briggs heads are notorious for this... Just a thought before you spend a bunch of money on Mods, but I would do heads and exhaust first, and then cam, and then carb if you are not happy. But this is just me.
Tue Nov 29, 2011 8:48 pm
I like the stock governor set up and the load carrying ability you gain from the cam. That is why I say cam, heads, and exhaust. I would actually do pistons and rods before the carb, unless I got a really good deal on a carb. That's just me.
I'm not saying he "needs" mods. He said he came in to some money and was looking in to heads, carb, and exhaust. Just said, I would do cam before carb.
Tue Nov 29, 2011 8:50 pm
Users browsing this forum: No registered users and 75 guests
