| Really big rig http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=30060 |
| Author: | stualaska [ Mon Jun 18, 2012 12:48 am ] |
| Post subject: | Really big rig |
I realize most the people on this forum don't have the same requirements as I. On the off chance this info could help someone I thought "why not"? I just picked up an old 24' X 60" Monarch with a decent bottom. The largest I've run, previously, was a 24' X 48" Alweld with a 35 SD. After taking care of some cosmetic repairs on the Monarch I mounted a High Transom SD on it and took it to the river. I loaded it down with about 1000 lbs not including the engine and battery. This is close to the load I have on a 5 day fishing trip on the Yukon. Upstream speeds in the current was 18mph. If I ran in the eddies next to shore it climbed to 20mph. Downstream speeds were consistently 23-24mph My best speeds came with the tach reading 3550-3570rpm. The engine is a box stock Briggs. Steering was very easy with no push or pull if the load was heavy on one side. Shifting considerable weight forward only decreased speed by 1 or 2 mph. If I kept the load balanced fore and aft the boat only drafted about 4 inches. I was impressed! I really didn't expect it to perform that well. |
| Author: | mud slinger 69 [ Mon Jun 18, 2012 7:00 am ] |
| Post subject: | Re: Really big rig |
Thats pretty good for a stock motor.Good info |
| Author: | MaXXis85 [ Mon Jun 18, 2012 8:22 am ] |
Stu, can you try running a prop with less pitch to get the RPM's up some? IIRC the 3500 RPM rpm range isnt the best to run the engine at a heavy load. 3700-3800 would be ideal and have more mechanical advantage. |
| Author: | OwenDickeson [ Mon Jun 18, 2012 8:27 am ] |
That's a good idea there white Marcus. |
| Author: | deltaduckmaster [ Mon Jun 18, 2012 9:14 am ] |
Yep Briggs don't like being loaded down and run 3500-3600 rpm's . They create a bad vibration and shit will happen lol!! When I bow fished out my small boat I ran a prop that would turn 4000 with my normal load!! |
| Author: | MaXXis85 [ Mon Jun 18, 2012 9:15 am ] |
| Author: | dog walker [ Mon Jun 18, 2012 10:37 am ] |
Critical speed,for those that don't know google is your friend Hats off to you once again Mr Stu |
| Author: | stualaska [ Mon Jun 18, 2012 4:48 pm ] |
| Author: | MaXXis85 [ Tue Jun 19, 2012 6:19 am ] |
| Author: | Duckdon [ Tue Jun 19, 2012 9:30 am ] |
without photo's it's all talk.........Duckdon |
| Author: | stualaska [ Tue Jun 19, 2012 8:17 pm ] |
| Author: | MaXXis85 [ Wed Jun 20, 2012 6:26 am ] |
Sweet. I would be curious to know if it does better. Theoretically speaking when pushing that much of a load you want some mechanical advantage to help you out and get strain off the motor! Sounds like you got a plan! |
| Author: | Duckdon [ Thu Jun 21, 2012 8:11 am ] |
Now that's a Yukon runner........ I'm in on the pike fishing just don't know when I can fit it in. Duckdon |
| Author: | Duckdon [ Thu Jun 21, 2012 8:14 am ] |
Just came to me..........That's a late "70's" vintage riveted boat with maybe a .83 thick hull and it's still getting the job done. Nice........Duckdon |
| Author: | austinabear [ Thu Jun 21, 2012 8:23 am ] |
That's Awesome! You could bring 6 people hunting along with their personal pirouges and still have room. |
| Author: | stualaska [ Thu Jun 21, 2012 10:56 am ] |
| Author: | txmudcutter [ Thu Jun 21, 2012 11:04 am ] |
Let us know how the new gears do stu I'm curious to see if it gets your rpms where they need to be |
| Author: | stualaska [ Thu Jun 21, 2012 2:40 pm ] |
| Author: | MaXXis85 [ Thu Jun 21, 2012 3:01 pm ] |
Stu Congrats on 50 years of marriage! |
| Author: | dguidry [ Thu Jun 21, 2012 3:15 pm ] |
Damn good job!!! 50 years and fishing and hunting Alaska today! The good life. |
| Author: | AK Dux [ Sun Jun 24, 2012 12:22 am ] |
Stu, Congrats on the 50th! I'm curious about those RPM's too. Got your bud to weld my tunnel off...still not gettin it. John |
