It is currently Wed Jun 25, 2025 5:17 am
Reply to topic  [ 5 posts ]
 Tall or short transom
Post Tall or short transom
Do surface drive mud motors work with both tall and short transoms without modifications?
Thu Jul 26, 2012 4:37 pm
Post Re: Tall or short transom
They are built to work on one or the other.
Thu Jul 26, 2012 4:39 pm
Ok thanks, i have a 27 mb mini on a short transom, and i was looking to get a little bigger boat. I found one used but it had a tall transom. I was hoping it would work, but i guess ill keep looking.
Thu Jul 26, 2012 4:57 pm
You can change some parts on your motor to make it work, or you can have the transom cut down. I would convert the motor to a tall, but not sure how much that runs for your motor. Fixing the transom should be in the 2-400 range.
Thu Jul 26, 2012 5:45 pm
others can confirm or deny, but you may be able to get a longer outdrive (32" or 40") and accomplish the same thing by getting the prop lower. not 100% sure this would work but this way you'd always have the longer drive if you went back to short transom
[Stage 2.5]
Thu Jul 26, 2012 7:59 pm
Users browsing this forum: No registered users and 54 guests
