The Legend
Joined: Thu Dec 15, 2011 8:29 pm Posts: 775 Location: Bridge City, TX
 "New" 17' x 54" Xtreme w/35 GTR
Well I couldn't take it anymore. I sold my last Pro-Drive in 2007 and haven't had a mudmotor since. Boy a lot has changed since I had one. I've been following this site for awhile and have learned a lot. I will admit I'm not too mechanically inclined with these things with all the mods now. I will definitely let one of the guys mentioned on this site handle it.
I won't waste too much time talking about speeds or if I liked it. The boat is kick ass and hauls ass for stock so I pretty much think that's enough said. Mods won't be too far away but I wanna learn the damn thing stock first.
I do have one question though, I have the idle rpms set correctly (1100ish). The boat is running upper 20s all day long at 3800ish lol. My only question is this, every time I engage the clutch whether it be forward or reverse, it wants to die unless I give it some gas. What could be the cause of this if when it's in neutral everything's set correctly. Try to remember, i'm not the most proficient at these things so dummy me down a bit.
_________________ 16.5' x 46" Instagator w/25GTRRRR SetxPerformanceshop.com or (409)548-4477
Sun Aug 05, 2012 9:21 pm |
Shellblastin
Joined: Sat Jul 23, 2011 7:55 pm Posts: 78 Location: Bridge City, Tx
 Re: "New" 17' x 54" Xtreme w/35 GTR
its not uncommon for the motor to die every once in a while if prop is under load/in thick mud when you engauge the motor into gear. Idk if its comparable to the 35 but my 23 is around 1200ish rpm range on the idle and sometimes i have to get the rpms up to engauge the clutch while in the mud. May just need to increase the idle just a bit to solve your problem.
_________________ 1754 Extreme/35GTR (409-988-6604)
Sun Aug 05, 2012 9:39 pm |
Bayoublackhunter
Joined: Sat Oct 02, 2010 4:55 pm Posts: 1192 Location: BAYOU BLACK
 Re: Re: "New" 17' x 54" Xtreme w/35 GTR
_________________ 35gtr on a 1854 Deep South Custom 1436 flat pushed by a 16 GDLT
Mon Aug 06, 2012 5:13 am |
The Legend
Thanks for the help. Before I bought the boat and motor I could've swore I read while searching that the idle should be set from 1100-1200. 1450 sounds like I lot. I did notice when I bumped it up from 950 to 1100 it still goes down to around 850 then picks back up if it doesn't die. Almost like its starving for fuel?!?!
Mon Aug 06, 2012 7:05 am |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
If it were starving for fuel it would run like shit no matter what the rpm's are. I doubt that's the problem..
_________________ 35 GTR - 1754 Extreme
Mon Aug 06, 2012 7:27 am |
txmudcutter
Joined: Mon Jan 30, 2012 9:08 am Posts: 2307 Location: Nederland, TX (SETX)
Got any pics?
Mon Aug 06, 2012 9:17 am |
muddawgchuck
Joined: Fri Oct 01, 2010 9:22 pm Posts: 959 Location: Spurger Tx.
The Legend ???? Wondering if this is who i think it is?
_________________ 18x54 WC custom 36PD EFI
Mon Aug 06, 2012 9:42 am |
Woodiebuster
set your Idle to 1450 out of water.
Its just bogging down in the water/mud without enough momentum to keep it running, perfectly normal.
Mon Aug 06, 2012 10:06 am |
The Legend
I'll set it for 1450 this afternoon and go run it. I'd post pics but I don't have the first clue of how to do that.
Mon Aug 06, 2012 10:16 am |
The Legend
Yes Single "O" it's me!!!
Mon Aug 06, 2012 10:17 am |
The Legend
MudCutter, PM me your cell and i'll text you some!
Mon Aug 06, 2012 10:19 am |
muddawgchuck
Mon Aug 06, 2012 10:33 am |
The Legend
lol you do that enough at work!
Mon Aug 06, 2012 10:52 am |
Nate
Joined: Sun Jun 17, 2012 1:30 pm Posts: 425 Location: Houma, LA
Mine is doing the same thing..No mud or anything just clutch it in deep water and it dies if i dont get on the gas...adjusting the idle didnt help still trying to figure it out
_________________ 1944 skiff with 35 GTR
Mon Aug 06, 2012 4:37 pm |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
I had this problem when I bought mine. I adjusted the carb and have my idle set at about 1000 out of water. Does fine for me.
Mon Aug 06, 2012 5:27 pm |
The Legend
Talked to Hoyt today and he said set the rpms at 1350. Talked to a few other members via phone and they all said 1200-1250. Either way, it's doing the same thing. How do you adjust the carb and what are you adjusting?
Mon Aug 06, 2012 6:08 pm |
The Legend
Well after a brief discussion on the phone with Camo he got me fixed up. Motor is idling around 1250 rpms, gov controls around 4220. When I engage the clutch, no more dying. Just some fine tuning is all it was. Hopefully tomorrow the weather will be better and i'll go hit the marsh and run it. Maybe try to catch a few reds while i'm at it. Big thanks to Rob and Chuck for the help.
Mon Aug 06, 2012 7:43 pm |
Team Camo
Glad you got it squared away. Hopefully when I get my new rig in we'll have some time for a ride before season opens.
Mon Aug 06, 2012 10:54 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Legend what did you do?
Tapatalk 2
_________________ 1850 & 36pd
Tue Aug 07, 2012 12:04 am |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re:
Tue Aug 07, 2012 5:59 am |
txmudcutter
 Re: Re:
Tue Aug 07, 2012 8:05 am |
The Legend
From what I hear, It's G-14 "Classified" top secret Med, the idle and gov screw were way out of whack. Not to mention you had to squeeze the throttle handle about an 1.5" before it would bite. Nothing serious, just cosmetic stuff the dealer didn't do before I picked it up. Rob walked me through after about a 2 min conversation on the phone.
Tue Aug 07, 2012 9:15 am |
The Legend
10-4 about the ride too. I can't wait.
Tue Aug 07, 2012 9:16 am |
Team Camo
 Re: Re: Re:
Tue Aug 07, 2012 10:11 am |
txmudcutter
 Re: Re: Re:
Tue Aug 07, 2012 10:26 am |
Woodiebuster
Rob, have you even had one long enough to break in?
Tue Aug 07, 2012 12:30 pm |
Team Camo
Just barely, but this is Brent's thread, yall quit ninja'n it up & I'll send yall some autographed pics or something, lol
Tue Aug 07, 2012 12:43 pm |
muddawgchuck
Its ok Rob he is used to gettting stepped on lol.
Tue Aug 07, 2012 1:03 pm |
