It is currently Fri Dec 19, 2025 9:20 am
Reply to topic  [ 9 posts ]
 false floor questions
Post false floor questions
Those with welded in floors, is the back completely sealed as well? Is the false floor completely water tight? Do you have a drain plug in the false floor section to drain (condensation, relieve pressure build up due to heat in summer? Need some design ideas. Also, the 1.5" drains that I see so many have. Pros / Cons, where the hell do you get a plug that big?
Mon Sep 17, 2012 11:33 am
Post Re: false floor questions
1.5 ain't big that is a standard size and I think Walmart has them, I've seen some 3 inch drains!
Mon Sep 17, 2012 2:53 pm
I've always used 1" sch 80 pipe when building mine which fits a standard size plug.
Tue Sep 18, 2012 4:41 am
Mine is welded evry couple of inches or so give or take. Just enough to let water drain and not let trash in
Tue Sep 18, 2012 5:13 am
If it is completely sealed, put two drain plugs, one on each side at the back for exactly what you said.
Tue Sep 18, 2012 6:48 am
Mines open in the back so water will fall into bottom of the boat to bilge out
Tue Sep 18, 2012 8:56 am
Yea I don't mean a sealed floor that goes all the way to the transom.
Tue Sep 18, 2012 9:24 am
that was the only problem I thought of is trash getting under it. Filling the hull with mud and crap adding weight. With a riveted floor with gutters, you could drill out the rivets everynow and then and clean out underneath it. Then just rivet it back.
Tue Sep 18, 2012 11:10 am
Tue Sep 18, 2012 1:07 pm
