| false floor questions http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=32458 |
| Author: | banded-mallard [ Mon Sep 17, 2012 11:33 am ] |
| Post subject: | false floor questions |
Those with welded in floors, is the back completely sealed as well? Is the false floor completely water tight? Do you have a drain plug in the false floor section to drain (condensation, relieve pressure build up due to heat in summer? Need some design ideas. Also, the 1.5" drains that I see so many have. Pros / Cons, where the hell do you get a plug that big? |
| Author: | CCC [ Mon Sep 17, 2012 2:53 pm ] |
| Post subject: | Re: false floor questions |
1.5 ain't big that is a standard size and I think Walmart has them, I've seen some 3 inch drains! |
| Author: | banded-mallard [ Tue Sep 18, 2012 4:41 am ] |
I've always used 1" sch 80 pipe when building mine which fits a standard size plug. |
| Author: | take'emgator [ Tue Sep 18, 2012 5:13 am ] |
Mine is welded evry couple of inches or so give or take. Just enough to let water drain and not let trash in |
| Author: | OwenDickeson [ Tue Sep 18, 2012 6:48 am ] |
If it is completely sealed, put two drain plugs, one on each side at the back for exactly what you said. |
| Author: | woodysqueal23 [ Tue Sep 18, 2012 8:56 am ] |
Mines open in the back so water will fall into bottom of the boat to bilge out |
| Author: | OwenDickeson [ Tue Sep 18, 2012 9:24 am ] |
Yea I don't mean a sealed floor that goes all the way to the transom. |
| Author: | banded-mallard [ Tue Sep 18, 2012 11:10 am ] |
that was the only problem I thought of is trash getting under it. Filling the hull with mud and crap adding weight. With a riveted floor with gutters, you could drill out the rivets everynow and then and clean out underneath it. Then just rivet it back. |
| Author: | woodysqueal23 [ Tue Sep 18, 2012 1:07 pm ] |
