19X46 Ro Ro Build 36hp PD Head Work/Carb/Exhaust http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=3709 |
Author: | UNCLE-J [ Wed Aug 05, 2009 2:39 pm ] |
Post subject: | 19X46 Ro Ro Build 36hp PD Head Work/Carb/Exhaust |
MM Brand: PRODRIVE Horsepower: 36hp Boat Brand: Ro Ro Build Boat Size: 19'x46" Boat Layout: V Bow Open Hull, with a 50" Front Deck. Deck includes a 20 gallon gas tank. Speeds | Shallow Water: 32 Speeds | Deep Water: 30 Total Boat Load With Gear Etc: With Approx. 1200#'s, boat still runs 26mph Conditions Tested In: Everything Except Cement or LimestoneGEDC0728.JPGGEDC0729.JPG |
Author: | tmorelli [ Wed Aug 05, 2009 8:10 pm ] |
Post subject: | Re: 19X46 Ro Ro Build 36hp PD Head Work/Carb/Exhaust |
Are those GPS speeds? What kind of mods on the motor? It looks stock. I've never seen a RO RO hull (RORO means: Roll On-Roll off to a heavy hauler). Is it all 1/8" alum? |
Author: | POKER1 [ Wed Aug 05, 2009 9:50 pm ] |
Those got to be modded speeds. |
Author: | basinhunter [ Thu Aug 06, 2009 7:40 am ] |
yea Poker he's got a stage 1 |
Author: | UNCLE-J [ Thu Aug 06, 2009 7:46 am ] |
READ MY SUBJECT LINE.. ALSO, READ ABOVE THE PICTURE. "BEFORE New Exhaust, Carburator, and Head Work" NOTE !! I have never ran it yet without a load. |
Author: | bayouboy [ Thu Aug 06, 2009 8:20 pm ] |
Author: | UNCLE-J [ Fri Aug 07, 2009 9:30 am ] |
I'm not just a weekend warrior.. I actually use mine... Its not getting wet unless its for a reason.. Yes, if you call, I will put it over and pull you out.. mud.jpg |
Author: | POKER1 [ Fri Aug 07, 2009 11:35 am ] |
Author: | UNCLE-J [ Fri Aug 07, 2009 8:09 pm ] |
Poker, I am going to try to get away and go run it this weekend light. Then I will post results.. Just unsure how its going to run due to having a 24 gallon gas tank in front. Without weight in the back, I am afraid that it may suck... |
Author: | tmorelli [ Fri Aug 07, 2009 8:34 pm ] |
I wouldnt expect that much trouble. 24 gallons of gas is = 1 well built college cheerleader. or.......................... Dont put 24 gallons of gas in it. |
Author: | UNCLE-J [ Fri Aug 07, 2009 9:03 pm ] |
LOL I already have 20+ gallons in it.. I wish I could trade the 20 gallons of fuel for a Thick College Cheer Leader..1068-fat-cheerleader.jpg |
Author: | POKER1 [ Fri Aug 07, 2009 9:05 pm ] |
Author: | dpd [ Sat Aug 08, 2009 4:49 am ] |
Got dayum Uncle J. I thought I was sick in da head and went over kill with an 18 gallon gas tank. You got 20+? Where ya going? Cuba? Just kidding. Congrats on the new rig. Everything looks well laid out and will serve you well. I may see you around some time. I play on Lake Verret every now and then. |
Author: | UNCLE-J [ Sat Aug 08, 2009 8:39 am ] |
It wasnt measured out.. When I built the boat, i wanted to add front deck, and a gas tank was the first thought that came to mind. |
