PRODRIVE http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=37174 |
Author: | CZECHHOME [ Sun Feb 03, 2013 8:48 am ] |
Post subject: | PRODRIVE |
I HAVE A X36 PRODIVE WITH THE POWER REVERSE THE BOAT IS F86 1851V EXCEL BOAT WITH THREE GUYS AND GEAR THE ONLY DOES 16-18 ON A GOOD DAY . WITH NO GEAR WITH ONE PERSON ABOUT 23-25 IS THIS ABOUT RIGHT SEEMS SLOW . I ALSO HAVE A MOD 1 ON THE MOTOR |
Author: | eljefe [ Sun Feb 03, 2013 8:50 am ] |
Post subject: | Re: PRODRIVE |
get a better boat.....you should be running 27-29 empty......also get some tiller time, it may just be you havent found the sweet spot on the trim... |
Author: | CZECHHOME [ Sun Feb 03, 2013 8:55 am ] |
I like the boat I have had it about year and half I have tried everthing . |
Author: | eljefe [ Sun Feb 03, 2013 8:57 am ] |
what rpms are you getting wot? you could buy a new boat for what you will be spending on mods to achieve the speeds other boats get.... |
Author: | CZECHHOME [ Sun Feb 03, 2013 9:06 am ] |
4200 4250 there and about Thought about to sell the boat and motor and trying something new. We hunt a few places that are a good ride take for ever |
Author: | eljefe [ Sun Feb 03, 2013 9:36 am ] |
with the rpms you are turning, measure your prop, if prop is good then boat is your problem. |
Author: | TX Aggie '06 [ Sun Feb 03, 2013 9:45 am ] |
Other than what eljefe said, I'm assuming you have the correct motor height and transom height? Tall - tall or short-short. Sent from my MB865 using Tapatalk 2 |
Author: | SCmudder7071 [ Sun Feb 03, 2013 12:42 pm ] |
Possibly need to shim the motor to reach the desired transom angle? |
Author: | eljefe [ Sun Feb 03, 2013 12:43 pm ] |
yep transom angle could be the issue also.... |
Author: | CZECHHOME [ Sun Feb 03, 2013 2:10 pm ] |
It has the tall 20 in transon and long shank on the prodrive . The prop is good new as of the transon angle dont no never thought of that one . does anyone no what it is for a proddrive and f86 excel |
Author: | nasty [ Sun Feb 03, 2013 3:02 pm ] |
On an excel... Prolly gonna be set for a mutt buddy. What mutt buddy? 18-20degree angle? And the right transom angle for a pro drive, so I've been told is the same for an outboard.. 12-15 |
Author: | CZECHHOME [ Mon Feb 04, 2013 4:42 pm ] |
F 86 is 15 degree and I talked to pro drive and they said thats will work just fine . So I will sell this one and start over ![]() |
Author: | JIMMY W [ Mon Feb 04, 2013 5:52 pm ] |
Think a little this time! |
Author: | wiriverhunter [ Mon Feb 04, 2013 6:00 pm ] |
The excels are really heavy boats (I had one), your not going to get great performance out of that hill, without a lot mods.Your best bet is to stick with the pd(unless you want a different motor) and go to a better hull. |
Author: | BlueShamu [ Mon Feb 04, 2013 7:29 pm ] |
Your speeds are probably close to right with a stock motor and that boat in deep water. Mods, I couldn't say. They are similar to what I get on stock. I am probably slower loaded in deep water. Shallow and loaded is totally different story for me. Loaded down, mine is like a tug boat in deep water. Makes for a long trip down the bayou black marina canal and ICW. It's a relief to hit turtle bayou pipeline and ride the edge of the marsh. I am no expert by any means, but from what I have read on here, the vee on the Excel probably hurting you. Just a guess. Sent using Morse Code from my not so smart phone. |
Author: | CZECHHOME [ Wed Feb 06, 2013 6:12 pm ] |
I thought I did look and think about it , but it is funny how much more you find after you buy . i was thinking about getting a mud buddy 55 mag , may just hunt with ome more year then sell |
