Full floor or gutters? Catwalk or not?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=38455
Page 1 of 2
Author:  doubleBanded [ Thu Mar 07, 2013 11:01 am ]
Post subject:  Full floor or gutters? Catwalk or not?
Gettin a boat built real soon 1854 or 1850 can't really decide if I want a full floor or not? Any pros and cons you guys have would help me out in my build. Catwalks? I am using the boat for fishing and huntin Louisiana marsh and pearl river area. Any info would help
Author:  Beadlejuicejr [ Thu Mar 07, 2013 11:01 am ]
Post subject:  Re: Full floor or gutters? Catwalk or not?
Full floor and cat walks you'll be happy with it
Author:  Kmoppert [ Thu Mar 07, 2013 11:02 am ]
Full floor. Gutters and gaps are hard to clean and a PITA.
Author:  doubleBanded [ Thu Mar 07, 2013 11:05 am ]
Does that add that much weight to the boat? When u have full floor and catwalks verse gutters with no catwalk? Or would you not even tell the difference in performance
Author:  T-Bubba [ Thu Mar 07, 2013 11:06 am ]
you can wash everything into the gutters...
go with catwalks
Author:  Kmoppert [ Thu Mar 07, 2013 11:07 am ]
My next rig will have a sealed full floor and a drop down bilge area against the transom to wash crap into.
Author:  OwenDickeson [ Thu Mar 07, 2013 11:11 am ]
I prefer the gutters.
Author:  CJB [ Thu Mar 07, 2013 11:12 am ]
Author:  OwenDickeson [ Thu Mar 07, 2013 11:13 am ]
Author:  doubleBanded [ Thu Mar 07, 2013 11:18 am ]
CJB nice rig! Like the cup holder
Author:  doubleBanded [ Thu Mar 07, 2013 11:20 am ]
Owen u have a picture of ur boat with gutters? Are they all the same width
Author:  Beadlejuicejr [ Thu Mar 07, 2013 11:29 am ]
Author:  cash [ Thu Mar 07, 2013 11:32 am ]
My boat is 1854 with catwalks and full floor. I have had both and prefer the full floor. I think the added weight of full floor and catwalks is negligable.
Author:  jmoney [ Thu Mar 07, 2013 11:47 am ]
Def get catwalks and a full floor! i have a 1754 extreme series with the 10" catwalks and love it. it takes away negligible floor space since the beam is wider than the floor.
Author:  doubleBanded [ Thu Mar 07, 2013 1:18 pm ]
Looks nice!
Author:  eljefe [ Thu Mar 07, 2013 1:34 pm ]
gutters with 2" drains.......easy to wash out, nothing hangs up between cross braces....wash everything to gutter then out the back. The gutters on my boat are 1" at the bottom.
Author:  grizzon30's [ Thu Mar 07, 2013 1:35 pm ]
Gutters are a pita! They get full of leaves, twigs, and all kinds of other stuff. I wish mine didn't have gutters and if I could find a good way to make it a full floor easily cheaply I'd do it.
Author:  CJB [ Thu Mar 07, 2013 1:38 pm ]
Author:  CCC [ Thu Mar 07, 2013 2:02 pm ]
Gutters suck! They get filled up with cane and grass
Author:  eljefe [ Thu Mar 07, 2013 2:24 pm ]
are you guys idiots? spray them out!!! If you have a full floor with exposed cross braces, everything gets stuck on the cross brace with no where to go....with a gutter, you wash everything to the gutter and out the back....I guess if you have raised the full floor to above the cross braces you could wash everything out the back, but if you have water and mud in the boat it can only go back to the driver, not off the sides into the gutter. also when shooting from boat, those emptys that land in the boat, end up in the gutter and with the 2" drains, I can wash empty shells, mud, vegitation out the back..........cat walks on a narrow boat like mine would be only for looks because you are no going to walk them, on a wider boat they would be nice, especially when a shelf is built bellow it and lighting tucked up underneath it..
Author:  barnes_53 [ Thu Mar 07, 2013 2:26 pm ]
Gutters suck when you have boxes that are welded to the side and the gutter runs under them. If you have an open hull go with the gutters. If you are adding boxes floor to wall.
Catwalks a huge value add.
Author:  doubleBanded [ Thu Mar 07, 2013 3:41 pm ]
It's an 1854 wit driver box. So I guess the gutters would run under it but I'm not to sure I've never had one built before. As for the catwalks. I just want them to have lighting under them
Author:  OwenDickeson [ Thu Mar 07, 2013 4:07 pm ]
The smaller catwalks are mainly for strength in the sides.
Author:  eljefe [ Thu Mar 07, 2013 4:10 pm ]
Here are mine...
sent by carrier pigeon...don't shoot it!!!!
Author:  eljefe [ Thu Mar 07, 2013 4:11 pm ]
Unless you are raising your floor above the cross braces I wouldn't do a full floor.
Author:  whistlingwings [ Thu Mar 07, 2013 4:17 pm ]
Author:  CCC [ Thu Mar 07, 2013 4:33 pm ]
Try and wash that out.... Not happening.
Author:  doubleBanded [ Thu Mar 07, 2013 4:36 pm ]
:lol:
Author:  dfou [ Thu Mar 07, 2013 4:36 pm ]
Author:  doubleBanded [ Thu Mar 07, 2013 4:38 pm ]
I'm gonna go with gutters and catwalks. I don't mind spending Lil time cleaning out the boat. Thanks for all the info
Author:  eljefe [ Thu Mar 07, 2013 4:52 pm ]
Your going to have to pick that shit out with or without gutters....your not washing it out if the back with a full floor and even with all that in the gutter, water will drain....
Author:  CCC [ Thu Mar 07, 2013 5:05 pm ]
My gutters are kinda skinny, either way it would be easier to clean with a full floor
Author:  Nate [ Thu Mar 07, 2013 5:13 pm ]
Author:  270Handiman [ Thu Mar 07, 2013 6:35 pm ]
Author:  Full Throttle [ Thu Mar 07, 2013 8:12 pm ]
I've had both... I like skinny gutters. The reason being is that if you are in and out of your boat a lot your floor will stay wet getting all of your gear wet as well. With the gutters, that water drains off the floor, keeping everything in your boat dryer/cleaner.
Cat walks wide enough to walk on are a must. You can have your floor full of gear and still walk easily about the boat if needed.
Author:  DuckHunterF250 [ Thu Mar 07, 2013 9:38 pm ]
Author:  Bayoublackhunter [ Thu Mar 07, 2013 9:47 pm ]
Author:  Bayoublackhunter [ Thu Mar 07, 2013 9:48 pm ]
I have big gutters , I like em cuz my boat stays dirty and full of mud, the floor stays clean because of the gutters, and with 2 2" plugs, almost everything washes out
Author:  Docott [ Thu Mar 07, 2013 10:25 pm ]
Definitely catwalks!!! They're my favorite feature of my boat! Corey talked me into 8" catwalks, and I'm glad he did! I thought they would be too wide and cut into the floor space by sticking I. To far, but they absolutely don't. In fact, far from taking up space, they actually add more usable space-rod/gun holders underneath, and you actually walk on them. On the way out to the blind, that's where people sit too. Get em wide enough to use. You'll be glad you did!
Author:  eljefe [ Fri Mar 08, 2013 7:18 am ]
If you leave gaps for water to drain in a full floor, you have to worry about buildup in the gutter under the floor. The gutter size depends on long brace placement. And if you get a hook? Do you want to cut your floor out to bang it out?
Page 1 of 2 All times are UTC - 6 hours
