18x54 GTB with 35GTR http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=41493 |
Author: | vic337 [ Fri Jun 07, 2013 12:27 am ] |
Post subject: | 18x54 GTB with 35GTR |
well yesterrday i was able to pick up my boat from gator tail. I put it in the water about an hour later and i love it. It is the extreme hull and handles very well. It has hoyt's stage 1 (cam, heads, exhaust). When i took it out it was me (240lbs) and a buddy (150lbs) 9 gallons of gas trolling motor with battery ice chest with budlight and the normal boating stuff. I was only running 26 bumping 27 @4150rpm, same stuff in the boat and just me 28 bumping 29at the same rpm. i think i should be getting a little more out of it I have seen the same size boat on here with stock motor on here running the same speed. thanks in advanced. |
Author: | swamprat26 [ Fri Jun 07, 2013 12:59 am ] |
Post subject: | Re: 18x54 GTB with 35GTR |
Turn your gov up until you at the rev limit or max out Sent from my iPhone using Tapatalk |
Author: | DUCK HEARSE [ Fri Jun 07, 2013 6:31 am ] |
Author: | vic337 [ Fri Jun 07, 2013 11:10 am ] |
I have done that already the best speed I get is @ 4150rpm. The prefilter is gone also, and it also backfires when revving down. Is that normal? |
Author: | muddonkey [ Fri Jun 07, 2013 5:32 pm ] |
What octane fuel are you running? Also you have to think about how much boat sits in the water. I have a 17x54 gtb and can bump 30 by myself(when I can keep the bow from bouncing). My buddy had a 18x48 build by Uncle-J with a 7.5 ft rake, he doesn't have much sitting in the water once he gets on plane. He has less drag and weight than what I have and stays infront and gets on plane quicker(maybe 20 yards in front). |
Author: | vic337 [ Fri Jun 07, 2013 9:01 pm ] |
I run 93 and it's gets on plane very quick and has loads of power down low. Would a carb help me with top end? It's it worth the money? |
Author: | msm8281 [ Fri Jun 07, 2013 9:06 pm ] |
Yes if you have the extra cash...not worth it if you dont. |
Author: | forever draggin [ Fri Jun 07, 2013 10:19 pm ] |
If u have cams heads and exhaust those speeds r horrible |
Author: | vic337 [ Sat Jun 08, 2013 11:24 am ] |
It's only had about 5 hours on it when I got the speeds, will it get better after it breaks in? Should I just call Hoyt and tell him what's going on and go from there? |
Author: | Kmoppert [ Sat Jun 08, 2013 12:53 pm ] |
Author: | JIMMY W [ Sat Jun 08, 2013 2:23 pm ] |
Author: | bbarras85 [ Sat Jun 08, 2013 3:11 pm ] |
Yeah. Just me in my boat I bump 29 bone stock. And I have a console rig. Something isn't right |
