new boat http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=44602 |
Author: | GREENMOCCASIN09 [ Fri Aug 23, 2013 10:33 pm ] |
Post subject: | new boat |
Gator tail 18x48 extreme w/35gtr ran 25mph up current and 26.6 down current . Didn't have a chance to run it long because of work. All deep water speeds. 3700 to 3800 rpms but seems to run a lil slower than normal? |
Author: | GREENMOCCASIN09 [ Fri Aug 23, 2013 10:36 pm ] |
Post subject: | Re: new boat |
Sorry for the short review. Will do a more indepth review with pics later when I put her back in the water |
Author: | SCmudder7071 [ Fri Aug 23, 2013 10:45 pm ] |
An 1848 Extreme? |
Author: | brasso [ Sat Aug 24, 2013 12:31 am ] |
Didint know extreme came in a 48" ? Those speeds do seem somewhat low... Your RPMs are a bit low too. What hole are you running the pin in? |
Author: | GREENMOCCASIN09 [ Sat Aug 24, 2013 3:41 am ] |
Its a 18x48 narrow. Theres four holes on the transom clamp, the pin is in the second one from the top. And when I would watch my gps and trim up any more I would lose speed. |
Author: | Wildberry [ Sat Aug 24, 2013 5:11 am ] |
There is 4 places for the pin ? thought there were only 3.... |
Author: | GREENMOCCASIN09 [ Sat Aug 24, 2013 7:19 am ] |
Four on my motor. I always heard the middle hole but mine has four holes |
Author: | SCmudder7071 [ Sat Aug 24, 2013 7:48 am ] |
New GTs have 4 now. Bump RPMs to 4300 OOW and play around with pin locations. Go ahead and put the factory bolt on the bottom hole and get you a Mercury 20hp quick release trim pin so when you get on the thick stuff you can just pull it out and let the motor go to the bottom bolt without having to pull tools out. |
Author: | GREENMOCCASIN09 [ Sat Aug 24, 2013 8:29 am ] |
Author: | Team Camo [ Sat Aug 24, 2013 9:49 am ] |
48" Extreme is new hull option. I like it a lot. I agree, get the rpm up till it's on rev limiter (coils). Instead of hunting down a Merc pin that may or may not fit, go to hardware store & get a 3/8x10" bolt & a small hitch pin. Cost <$10 & it will for sure work. |
Author: | GREENMOCCASIN09 [ Sat Aug 24, 2013 10:34 am ] |
Author: | bbarras85 [ Sun Aug 25, 2013 7:25 am ] |
Author: | Team Camo [ Sun Aug 25, 2013 8:01 pm ] |
Author: | GREENMOCCASIN09 [ Sun Aug 25, 2013 8:39 pm ] |
Well took the boat out again today after I left work . Me 170lbs, old lady 125lbs, 9gallons of fuel, trollingmotor and two batteries regular boat stuff. Extended front deck open floor. Held 27 to 27.6 deep water. |
Author: | Team Camo [ Sun Aug 25, 2013 8:49 pm ] |
Not bad at all, now change your avatar. ![]() |
Author: | GREENMOCCASIN09 [ Sun Aug 25, 2013 8:57 pm ] |
That's what I was just trying to do but can't figure it out!!! |
Author: | sela_native [ Sun Aug 25, 2013 9:09 pm ] |
Go to your settings page which is under the big banner at the top of the page. In your profile you will see where to change it. |
Author: | sela_native [ Sun Aug 25, 2013 9:13 pm ] |
User control panel |
Author: | GREENMOCCASIN09 [ Sun Aug 25, 2013 9:26 pm ] |
Thanks sela |
Author: | CAJUN OUTLAW [ Sun Aug 25, 2013 9:48 pm ] |
Great, now just "add" a couple imaginary mph to your top speed, hell it "feels" like u doin 30 doesn't it? Enjoy the new rig and remember....kill switch, lifejacket, and don't drink too much kool-aid . ![]() |
Author: | GREENMOCCASIN09 [ Mon Aug 26, 2013 5:33 pm ] |
Author: | SCmudder7071 [ Mon Aug 26, 2013 6:06 pm ] |
I really want to see pics of this rig. Could be exactly what I order in February. |
Author: | GREENMOCCASIN09 [ Mon Aug 26, 2013 7:03 pm ] |
Author: | pokey79 [ Mon Aug 26, 2013 7:12 pm ] |
GT needs to update there site or sumtinn!!!!! u still cant find a 48'' option on a extreme haul!! cause lord knows if I would have seen that I would have went with 48 extreme instead of 46 flat J/S |
Author: | Team Camo [ Mon Aug 26, 2013 7:29 pm ] |
Wasn't available when you got yours. |
Author: | bmartina [ Mon Aug 26, 2013 7:29 pm ] |
I wanna see some pics of this thing |
Author: | GREENMOCCASIN09 [ Mon Aug 26, 2013 9:03 pm ] |
