stu
Joined: Wed Mar 16, 2011 2:35 pm Posts: 608 Location: Deerfield Beach FL,
 Swomp 35
Got the new Longtail on and ran it today. First time out ran 12 mph with two kids, six gallons of gas, and myself. Took it out of the water and moved the Motor mount bolt to the forward position and shimmed the Cav plate. Ran 18mph consistently after the adjustments with the same load. Deep or shallow water didn't seem to make much difference. Still learning but real happy with the motor.
_________________ Swomp 35 on an 1848 Alumitec Custom
Sun Sep 08, 2013 11:35 am |
FRANKtheTAU
 Re: Swomp 35
What size boat? I think there may be some more speed you can pick up by dialing everything in!
Sun Sep 08, 2013 12:15 pm |
stu
 Re: Swomp 35
Sun Sep 08, 2013 12:57 pm |
Glades Ranger
 Re: Swomp 35
Congratulations, Stu! After break-in, I guess you can tweak the throttle to around 4200 rpm out of the water, and maybe realize another 1-2 mph. When planing, does the prop run fully submerged? Is that an all-welded Lowe? If so, that is considerable weight but you have a good match. I added steelflex to my 1648 grizzly to reduce friction when running in any mud/veggies and that helped. I relocated the battery (46#) up front because there was not enough room for both the 6 gallon tank and it. I also recommend synthetic oil/grease perhaps after your first oil change. Have fun!
Sun Sep 08, 2013 4:50 pm |
FRANKtheTAU
 Re: Swomp 35
Well never mind. A welded 1752 is a heavy boat. That 35 may hit 20mph but it'll take some dialing in. Those motors are definitely some fine pieces of work though, aren't they?
Sun Sep 08, 2013 4:58 pm |
stu
 Re: Swomp 35
Thanks for the input guys. Glades, yes it's an all welded boat. With the weight and the semi V hull, I'm happy to get 19 mph out of it. Gonna take it out today after work and play with the weight distribution and get a little more experience operating it. Really enjoying running in areas my outboard couldn't go. Doing any scouting Glades?
Mon Sep 09, 2013 4:42 am |
stu
 Re: Swomp 35
Mon Sep 09, 2013 4:44 am |
Glades Ranger
 Re: Swomp 35
10-4, stu! The high water closures have forced my hand and I must scout the areas north. Enjoy the beastly 35, I would love to try it on my hull. That speed you are getting is fine, enjoy the ride and wear your kill switch lanyard.
Wed Sep 11, 2013 4:36 am |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
 Re: Swomp 35
How are the forearms holding up with that motor? Is it a workout or pretty easy?
_________________ 23 swomp/ 1542 tracker
Wed Sep 11, 2013 2:18 pm |
FRANKtheTAU
 Re: Swomp 35
I've driven a back water motor with a 33hp Generac. Literally zero difference between it and my 23.
Wed Sep 11, 2013 5:11 pm |
Trousertrout
 Re: Swomp 35
Don't mean to hijack thread but. Frank when you get the boat hung up and the prop has mud/water to work with does the prop want to dig down real deep?
Wed Sep 11, 2013 5:46 pm |
stu
 Re: Swomp 35
Wed Sep 11, 2013 6:58 pm |
FRANKtheTAU
 Re: Swomp 35
Trouser I know what you're talking about. All longtails do that. You can use the bump stop to handle some of that. I just let the prop dig and work it back and forth.
Wed Sep 11, 2013 7:35 pm |
stu
 Re: Swomp 35
Frank, when you first got your motor, did you have any problems with the prop wanting to blow out of the water at WOT? If so, how did you resolve it.
Thu Sep 12, 2013 9:11 am |
FRANKtheTAU
 Re: Swomp 35
Stu do you have any shims under your cavitation plate? Sounds like the trailing edge of your cavitation plate needs to be angled up SLIGHTLY.
Thu Sep 12, 2013 9:42 am |
stu
 Re: Swomp 35
Thu Sep 12, 2013 10:41 am |
