It is currently Thu Jan 29, 2026 11:55 am
Reply to topic  [ 3 posts ]
 14x44 welded boat with 23hp go devil surface drive
Post 14x44 welded boat with 23hp go devil surface drive
i have a 14 foot welded boat with 23hp go devil surface drive with me at 160 pounds an my friend that
weighs 115 pounds an 2 gallons of feul its only running between 16 to 18mph an its turning 3600 to 3700 rpm
Mon Nov 18, 2013 11:10 pm
Post Re: 14x44 welded boat with 23hp go devil surface drive
What brand boat? Mod-v, flat bottom? How high is your transom? I'm new to this stuff, but you should be getting better speeds. Sounds like your transom is too short for your motor. If that is not the case, you need to play with your trim. I know I have to adjust mine acording to the load in the boat.
1648 GDSD 27 GDSD
Tue Nov 19, 2013 12:12 am
its a flat bottom an i believe its a alweld an i started lookig an i think i have a head leak so that probley the problem
Tue Nov 19, 2013 12:37 am
