Uncle J 18x54 w Stage 2 GTR 35 http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=49373 |
Author: | DeezNuts [ Mon Jan 20, 2014 5:11 pm ] |
Post subject: | Uncle J 18x54 w Stage 2 GTR 35 |
18x54 Uncle J GTR 35 w/ Stage 2 mods Alum Hull 1/8th 22" Sides Pipe Front 20" Transom,19degrees 3/16 Bottom Welded Subfloor 40" stow in, 20" stow under Spud Pole Holes and Pole Mount Custom Grab Bar w/ Drink Holder 12 Gallon Gas Tank Winch receiver- removable Front Spud hole be offset. 4" Catwalk Gas Tank Assembly Kit Spot for Switch Panel Full Hunt Deck Custom Paint Max 4 Camo 3 Seat Bases I finally was able to get a couple of hours in deep water today. I ran solo, 12gal of fuel and a slurpee. Was not able to hit the shallow stuff yet. I had a local buddy here add a permanent tank and light mounts for me. |
Author: | missile [ Mon Jan 20, 2014 6:48 pm ] |
Post subject: | Re: Uncle J 18x54 w Stage 2 GTR 35 |
Good looking rig |
Author: | banded-mallard [ Tue Jan 21, 2014 3:06 pm ] |
good looking rig. For a stage 2, you aught to get better speeds than that. I run 34+ in a stage 2 PD and could be faster if I pitch my prop. Check your prop for wear. |
Author: | diddyduck [ Tue Jan 21, 2014 3:09 pm ] |
Author: | dfou [ Tue Jan 21, 2014 5:50 pm ] |
Author: | banded-mallard [ Tue Jan 21, 2014 6:23 pm ] |
17'10" x48". 3/16" bottom, 1/8" sides, 5" cat walk. Fully welded false floor, ah fuck it. I can run that with 4 grown men in my shit with 15 gal of fuel, not a 6 gal portable. And I measured my prop the other day, it's 11 7/8", worn to shit. He should be running better. |
Author: | DeezNuts [ Tue Jan 21, 2014 6:26 pm ] |
@diddyduck...I have three hrs on the engine now and this is what I had done thru J...Cam, Timing Key, SS Exhaust, Kand N Filter, Head Work and Mikuni. I'm guessing this is considered a Stage 2? That being said...what do you suggest I do to get it up to par? |
Author: | OwenDickeson [ Tue Jan 21, 2014 6:53 pm ] |
I'd say you are not far off on the speed. I run 32 or so in my 1848, and I believe your boat would be a little heavier. How many rpm are you turning? |
Author: | missile [ Tue Jan 21, 2014 7:24 pm ] |
Just give it time you going to pick up a little more speed once the prop gets some hours and you get a little tiller time running it. ![]() |
Author: | nasty [ Tue Jan 21, 2014 8:23 pm ] |
How much tiller time u got dez? Kinda new to mm's? |
Author: | DeezNuts [ Tue Jan 21, 2014 8:28 pm ] |
100% Rookie. |
Author: | diddyduck [ Tue Jan 21, 2014 10:51 pm ] |
she'll break in and youll learn more on running it..wasnt really thinkingof the size of your boat...very nice looking rig and dfou cjb had this exact rig i believe with stage 2 pd running 34 35 |
Author: | Bigrich [ Wed Jan 22, 2014 4:25 am ] |
Nice rig for sure!!! |
Author: | dfou [ Wed Jan 22, 2014 7:47 am ] |
Author: | diddyduck [ Wed Jan 22, 2014 7:51 am ] |
Author: | Hernaja1 [ Wed Jan 22, 2014 7:57 am ] |
Where did u get those mobile seat stands ? Those are sweet !! |
Author: | CJB [ Wed Jan 22, 2014 8:46 am ] |
Author: | dfou [ Wed Jan 22, 2014 9:01 am ] |
Author: | diddyduck [ Wed Jan 22, 2014 9:03 am ] |
Author: | Buzz Killington [ Wed Jan 29, 2014 8:10 am ] |
boat looks like CJBs old one nice rig! |
