It is currently Fri Dec 26, 2025 7:43 am
Reply to topic  [ 14 posts ]
 35 GDSD pushing a 16x40 custom skiff
Post 35 GDSD pushing a 16x40 custom skiff
Like the motor it's fast and does good runs about 30-31 but sucks when you stop in the Lilly's while crawfishing. Thinking about switching back to a longtail again
Wed Sep 18, 2013 6:43 pm
Post Re: 35 GDSD pushing a 16x40 custom skiff
Cut off the cavitation plate, this will improve your performance in Lillie's and heavy vegetation. If you need pictures let me know
Wed Aug 20, 2014 5:37 am
Sun Aug 24, 2014 9:03 am
I'd like to see pics as we'll! Are there any draw backs/negative effects of cutting off the cav. Plate? I've often wondered why some companies choose a cavitation plate and some don't..??....
Sun Aug 24, 2014 4:42 pm
Eat - Sleep - Hunt ! ! !
Sun Aug 24, 2014 5:45 pm
When stopped in thick vegetation and Lilly's, trying to clear your prop it is like lifting a shovel full. When plate is cut in front of prop, it cuts and clears much easier
Sun Aug 24, 2014 7:28 pm
Junk
Tue Aug 26, 2014 8:32 am
this is a motor we cut off cavitation plate
Fri Aug 29, 2014 1:21 pm
That is actually a very good idea. It does catch in thick stuff from time to time. I increased my performance in grass by playing with the trim until I got it right. I have a longer boat and high transom though. My cavatation plate barely goes under water at idol.
40HP Gatortail
Fri Aug 29, 2014 4:27 pm
Makes a big difference in thick lillies
If you look at Gator tail or Mudbuddy they have no cavitation plate
and Pro drives plate doesn't cover prop
Fri Aug 29, 2014 5:15 pm
Tue Sep 09, 2014 7:40 pm
Thick vegetation !
Hydrilla and lillies
Other than that no
Tue Sep 09, 2014 10:12 pm
some people have brought up the advantages....Are there any DISadvantages to doing this?
Seems like once a person does this it would be hard to go back and replicate the exact angles of mounting the plate back on.
Wed Sep 10, 2014 7:29 am
We did not find any disadvantages
Go devil always could weld a new plate back on.
The original post said he was going back to a long tail , maybe he should try this before doing that. This will help him with the situation he explained
Thu Sep 11, 2014 4:58 am
