It is currently Mon Jun 16, 2025 9:24 pm
[ 1 post ] |
1740 Crawfish Skiff - 20hp Honda GD LT CM
certifiedcoonass
Joined: Wed Nov 12, 2014 12:18 am Posts: 26 Location: Da Basin, LA
MM Brand: Go Devil Type: Longtail Model: Crawfish Engine Manufacturer: Honda Horsepower: 20 Boat Brand: Custom Built Aluminum Skiff Boat Thickness: 1/8 in all around (getting a 3/16 bottom put on before crawfish season) Boat Size: 17 ft, 40 in bottom Boat Layout: Compartment and gas tank in front Speeds | Shallow Water: 20 Speeds | Deep Water: 19 Total Boat Load With Gear Etc: >10 loaded with crawfish Conditions Tested In: Everything da basin has to offer.
Comments: Well. When she runs, she runs alright. She don't like da thick lillies all dat much. Gotta have my buddy go to the front to even da weight if both of us stuck in thick mud. She like a woman. She always having problems. Every time you bring her somewhere. Although, every time you spend your hard earned time an money fixing da problems. So far, I've: Changed gas tank/ fuel line fittings Fixed da aluminum gas tank (tried to change fitting and it broke off so I had to redrill it and get it rewelded) Changed all da fuel lines/ fuel clamps Changed da fuel filter Changed da fuel bulb Changed da fuel pump Changed da battery Changed spark plugs multiple times Changed air filter multiple times Got a new carb kit put on by godevil Rewelded cracked muffler Changed starter Changed solenoid Changed grease fitting cap About to change seals
Bought her used from a fellow Crawfisherman who gave me a pretty good deal. Hopefully I'll eventually get everything worked out on her. Just put in a new 3/4 in plywood floor. Hoping to be able to get a 35 hp gator tail surface drive towards da end of dis upcoming crawfish season, so I can use dat da majority of crawfish season and da 20 just da last few weeks - month when da water gets really low and stuff gets really bad. I always put my phone in my drybox while crawfishing, so without dis being planned I don't have as many pictures on da water as I'd like. I'll attach da ones I do have for y'all doe. Tell me what y'all think.
Thu Nov 13, 2014 9:37 pm |
[ 1 post ] |
Users browsing this forum: No registered users and 39 guests |
