It is currently Tue Jun 17, 2025 11:01 pm
Reply to topic  [ 25 posts ]
 Tracker Grizzly 1648.. What mud motor?
Post Tracker Grizzly 1648.. What mud motor?
I have a Tracker Grizzly 1648 all weld with a 30 horse mercury. Im ready to get rid of the outboard and go to a mud motor. I understand that a modified v hull is not the best for a mud motor, but I do know that a mud motor will take that 1648 Tacker Grizzly a lot more places than my 30 horse outboard will. And I also like the modified v for running deeper water like we have on some of the lakes here in Florida. I hunt in Florida and am tired of clearing my prop and stopping to take weeds off of it. Plus I want to run decently shallow. I got pods for a Christmas present made by Beavertail so my boat should be more stable now. I asked for the small size designed for 14' to 16' foot boats, but I received the medium size made for 17' to 18' foot boats. When I got them I took them out to my boat and held them where they would be attached and they did not interfere with the turning and handling of my outboard. I think the mediums will fit my 1648 fine. I also like them being bigger as I would assume that they would hold more weight up and be more stable. So, I have a couple of questions... I am going to wait till after this duck season to get my mud motor, and I have decided on a 35 hp.. I have read many forums and seen where a surface drive is not good with pods, but I have also seen where they are alright if set up right. I would rather have a surface drive but if pods are a real problem with a surface drive, I wouldn't mind having a 35 hp long tail as long as it still pushes me fast. I hear they are a pain to drive though. So, will these larger pods interfere with turning on a surface drive if thats the route I take? Or could we set up this boat with a surface drive? I just need some advice dealing with what motor for my boat before I install these pods and purchase a mud motor.
Thu Dec 25, 2014 2:15 pm
Post Re: Tracker Grizzly 1648.. What mud motor?
Da fukk i said on the last post? :lol: :lol:
Refurbishing a Prodrive
Sun Dec 28, 2014 10:05 am
You will be aggravated right off the back with that boat and a surface drive. If you are set on a surface drive, don't get a heavy weighted one.
40HP Gatortail
Sun Dec 28, 2014 10:12 am
Medium pods make it a pain wit longtails! Won't be able to swing tail side to side... Longtails aren't hard to run if dialed in correctly
If its up high, it's coming to the ground
Sun Dec 28, 2014 10:54 am
I personally would sell the tracker 1648 with the outboard and start over. That being said , I have seen the 27 longtail and the 35 longtail move the 1648mv pretty good. There is a guy on toho that has a 35 gd surface drive that looks to move around 30. I would not put the pods on the boat with the longtail, you wont need them and it will hurt performance. Good luck and let us know how it works out.
Mon Dec 29, 2014 6:27 pm
The pods on my 1548 work great with my 20hp Longtail and Weldbilt boat. I run right at 20 solo with a worked over 9x4 prop turning it 4150rpm
I say if they help float the motor and are installed right, go for it. Different story with a surface drive.
-Custom pool noodle
-stage 4 water wings
Mon Dec 29, 2014 6:36 pm
Tue Dec 30, 2014 7:13 am
Thanks but mine runs fine. I have had several other props on this setup and with more pitch I kill my load carrying capacity. I can carry 3 and gear at 15-16mph at 3800RPM. With the 9x6, I had less top end loaded and unloaded. I'm working with 20hp. Momentum is the key. I'm not afraid to turn this Honda 4500+ RPM, folks in the carting world are running this same engine 5K and up on stock internals with no ill effects. I believe the sweet spot for this thing is 4000-4200, not 3600. Turning it that slow lugs the shit out of it and you can tell the difference just by listening to it. Sounds much happier at 4K.
-Custom pool noodle
Tue Dec 30, 2014 7:28 am
Tue Dec 30, 2014 10:30 am
Probably not, you'd be surprised.
The valves float at about 5200 on this thing. I don't run a governor and have hit a log and knocked the tiller out of my hand running WOT lol. Don't honestly know how many hours are on it. I've put 55 on it in a year and have had zero engine trouble minus some fuel delivery issues that weren't engine related. They're always overlooked I guess because they don't make many of the bigger hp engines but the Hondas are tough as nails and as reliable as anything I've seen on the water.
-Custom pool noodle
Tue Dec 30, 2014 10:54 am
That hull with a surface drive will do okay. I have a 15ft mod v with a 35gtr and it gets the job done. Do I want and need a true mud boat yes but this fit the budget at the time and hey it gets me where I want to go hunting except if there's a sand bar haha
1548 SEA ARK with 2014 GTR 35
02 DURAMAX- MORE POWER, LESS SMOKE
Tue Dec 30, 2014 3:30 pm
Had a grizzly tracker 1648 and put a 35 mud buddy on it. Ran it for three months and sold the hull. Do yourself a favor and sell your hull, i would say with your hull your handicape is at 70% easy.
2014 Gator Trax 1750
2014 MB 35 HP
Wed Dec 31, 2014 11:45 pm
New Member
I have been looking for some information... I also have a 2011 tracker grizzly 1648... I understand that the boat inst the best but I dont really wanna get rid of it. Im 22 and just getting out of school. I dont really have the money to buy a brand new setup. mud boats arent cheap. I need to know what size surface drive to go with. Go devil seems to be the lightest and most reliable from what ive read. The boat is rated for a 50hp outboard. However I hear the the mud motors are a lot heavier. The guy from go devil said i could get away with there 27hp model. I hear that the 35s are just to heavy and the motor wash will come over the back of the boat. Anyone out there have a 1648 tracker with a surface drive.... please help! And where can you find used mud motors im up in NY
Thu Feb 05, 2015 2:06 am
Thu Feb 05, 2015 9:34 pm
Not to mention, i have an alweld 16x48 with a 35 GDSD straight from the dealer, with a short transom and water doesnt come over the back.
I am gunna be slapping a 36 prodrive on there, which is heavier, and im still positive it will be good to go.
Thu Feb 05, 2015 9:36 pm
The tracker grizzly line of boats IMO is ridiculous in how much they weigh compared to a custom boat like gator trax
Thu Feb 05, 2015 9:51 pm
New Member
well the way my boat is set up now I could prob get 4 grand or better. however, i like the mod V because I also use the boat for diver ducks. How much are mud boats ?
Fri Feb 06, 2015 9:10 am
Get a 35. I have a gtr 35 on a boat smaller than that and it's fine, just have to be smart about how you drive, I've taken a few waves over the back and side from acting like an idiot but never enough to even turn the bilge on. Now if I swamped the back every time I stopped then my boat would def sink. Just be smart about it
Fri Feb 06, 2015 4:51 pm
Go for it, I run 24mph with 2 guys a blind an a dog with hunting load 23mph with 3 bigger guys an hunting load with a 36hp prodrive .
16x48 holds a 35 pretty well.....You will be disappointed in anything smaller
Fri Feb 06, 2015 5:00 pm
X2 this^^
B. MacDonald
Mon Feb 09, 2015 12:05 pm
Nice review.
Sent from my beeper
Mon Feb 09, 2015 6:33 pm
Just make sure the pods are set 1-2" below the bottom of the rest of the hull and youll be fine.
Mon Feb 09, 2015 6:57 pm
Mon Feb 09, 2015 9:14 pm
^^Max performance
Mon Feb 16, 2015 11:05 pm
Users browsing this forum: No registered users and 54 guests
