It is currently Wed Jun 18, 2025 2:45 pm
Reply to topic  [ 24 posts ]
 GDSD EFI - side by side on same 1844 hull
Post GDSD EFI - side by side on same 1844 hull
Speaking of Re-Powered Go Devils - ;)
Interesting side by side run thursday....
3 identical 1844 Go Devil hulls
1. My 7 year old 35 GDSD with seasoned prop
2. Brand new 35 GDSD carb model with new 3 blade
3. Brand new 35 GDSD EFI with new 3 blade
The new carb model with new prop was about 1 mph faster than my
7 year old stock 35 GDSD - but the EFI was 4 mph faster downwind
and 3.5 mph faster into the wind and 8" chop....
The EFI has considerably more "bottom end" power and quicker
throttle response which is where you really need it tooling thru
tight twisting bayous.... The EFI pulled away from me time and
time again in the "maze" that we like to run and was very impressive....
Even has a deeper throaty exhaust tone too....
Eat - Sleep - Hunt ! ! !
Fri Apr 03, 2015 10:04 am
Post Re: GDSD EFI - side by side on same 1844 hull
Now this is a good comparison. apples to apples it seems like
Fri Apr 03, 2015 10:14 am
But EFI could leave you stranded!
Fri Apr 03, 2015 10:18 am
We ran for a while after you left yesterday.
In the twistys, the round chine boats had my number lol, I dry-docked mine once coming into a turn too hot, that EFI 1844 pulled me back into the water though ;) on any kind of a straight run, my 1860 would pull away from both of them. Never checked the speed but I was probably 1-2mph faster than the EFI round chine boat, and.... Several mph faster than the carb boat. My boat handled the choppy water great also. We had a pretty long run into the wind and as long as it wasn't a cross wind trying to blow the bow of the boat around, the boat just got on top of the chop and rolled out.
-Custom pool noodle
-stage 4 water wings
Fri Apr 03, 2015 11:51 am
Good information.
40HP Gatortail
Fri Apr 03, 2015 12:28 pm
Fri Apr 03, 2015 3:15 pm
Fri Apr 03, 2015 3:20 pm
:shock: Giga is gonna mod his motor? :shock: :shock:
Fri Apr 03, 2015 3:23 pm
Fri Apr 03, 2015 3:31 pm
Fri Apr 03, 2015 3:36 pm
Fri Apr 03, 2015 7:56 pm
Fri Apr 03, 2015 8:10 pm
Couldn't you just use a good coating of dielectric grease on all connectors to help eliminate the the salt water problem. A little preventive maintenance goes a long ways with these things.
Fri Apr 03, 2015 8:21 pm
Mine gets a fresh water hose and a WD40 shower after every run, fresh or salt. The weatherpak connectors should be good to go but I plan on greasing them as well. Mine will be ran in 95% fresh water, a trip to the salt water is a rarity for me. Too many fish to be caught up in the river!!! :lol:
-Custom pool noodle
Fri Apr 03, 2015 8:43 pm
CRC Heavy-Duty Corrosion Inhibitor is your friend. It's like a spray wax in a can. The only thing that it will burn off of on these motors is the exhaust.
Just don't spray it on any part of the throttle linkage. That gets Boeshield T-9 on mine.
Sun Apr 05, 2015 8:20 am
Got to see new EFI GDSD in action saturday in hard packed veggies....
Extra bottom end power helped it power thru better than my GDSD carb model....
Sun Apr 12, 2015 6:54 am
This is great news to hear from the motors them selves
Sun Apr 12, 2015 1:53 pm
My boat wasn't light years faster on the long runs but would creep away from the pack. I get the best solo performance turning 4000-4050. Any more than that and it doesn't help speed, just throws a bigger roost. My EFI 1860 is faster on the stretch than a carb 1660 FWIW.
I got thru those hard packed lillies too without too much issue. Coming back across they had floated apart a bit and we just blew thru them.
-Custom pool noodle
Sun Apr 12, 2015 4:32 pm
Fri May 01, 2015 2:31 pm
ECM - issues continue to pop up when loose connections are present it fries the ECM
Sat May 23, 2015 7:21 pm
That's unfortunate to hear, hopefully it gets fixed. That's a pretty big problem to be caused by something that can happen pretty easily. I would venture to guess there's gonna be quite a few folks not too happy about it.
Sun May 24, 2015 5:09 am
Sun May 24, 2015 6:22 am
Sun May 24, 2015 7:01 am
FYI, I've got over 20hrs on mine as of yesterday and have had the engine and battery off the boat to be flipped, ran thru a torrential downpour a couple times (enough to kick on the auto bilge) had it sprayed with bow wash jumping 2-3ft rollers trying to get back to the ramp when the wind picked up. I have had absolutely zero issues with battery connections, ECM issues, anything of the sort. The boat still runs flawlessly. I know 20hrs is a drop in the bucket in comparison to most but it's already seen some pretty harsh running conditions. Hope that maybe puts a small amount of ease in some folks' minds about the Briggs EFI system. I'm still impressed with it every time I run it.
I pulled a 275lb guy on a big double tube (wider than the boat) and managed 22mph with someone else in the boat (law) and two big ice chests full to the top, a grill and the canopy up, also with two large batteries, and two full fuel tanks up front... The holeshot and tq difference is a real thing ;)
-Custom pool noodle
Sun May 24, 2015 9:03 am
Users browsing this forum: No registered users and 66 guests
