It is currently Thu Dec 25, 2025 9:05 pm
Reply to topic  [ 19 posts ]
 1848 GTB & 37 EFI GTR
Post 1848 GTB & 37 EFI GTR
Just going to do a quick preliminary write up. I took my boat out on Saturday for the first time. The load was trolling motor, two group 29 deep cycles group 24 starting battery, my girlfriend, my dog and I. I was running with the pin in the third from bottom hole, and my three blade prop. Can't say I looked at the tach a whole lot, but I know I was running just over 4000 rpms in shallow water most of the time. This is the first surface drive I have owned so I'm sure I've got some learning. My top speed was 28+ with cruising at 20 or so quite comfortably. Everyone talks about how much a smooth bottom, square chine slides, but unless I was making a super tight turn without letting off the throttle, it was a non-issue altogether. (I can see the issue being more apparent on a wider hull) I LOVE the instant reverse, it is great! The EFI motor is awesome, the throttle response is great, and the torque of the big block is great! I am very happy with everything about this boat. I may order a two blade prop and see how I like it. (I ordered a spare with the boat and never thought to ask for a two blade)
Specs:
-1848 GTB
-Gatortail installed accessory pkg b
-Diamond cut (b stock) hydro turf throughout
-Minn Kota V2 50lb w/riptide ipilot add on (apparently you can get a great deal on ipilot up here in WI when a local dealer accidentally orders riptide add on instead of power drive!!)
-2 group 29 batteries mounted under casting deck w/ 6 gallon fuel tank.
- Amazon 12" 72wt LED light bar
-Humminbird Helix 5 sonar/GPS combo mounted on gunnel (may build small grab bar console) transducer mounted on RAM kayak mount.
-37 GTR EFI
-18 ft McClain galvanized trailer
I still have yet to mount my promar 10 amp 2 bank onboard charger and order my gator glide.
Every day I'm paddlin'
Mon May 25, 2015 6:37 am
Hit 31mph at 4250 rpms with just me in the boat today. I would still say my "normal" top speed is 29.
Mon May 25, 2015 3:29 pm
Post Re: 1848 GTB & 37 EFI GTR
Expected numbers. That GPS you've got on there looks pretty nice.
Mon May 25, 2015 3:52 pm
Mon May 25, 2015 3:55 pm
Which humminbird is that?
-Custom pool noodle
-stage 4 water wings
Mon May 25, 2015 8:30 pm
Helix 5 sonar/gps
Mon May 25, 2015 8:33 pm
Thanks! That's about what I'm looking for.
-Custom pool noodle
Tue May 26, 2015 9:10 am
thanks for the review!
Bad ass rig ya got there. I swear those RAM mount transducer brackets are the best thing since sliced bread. I would have destroyed atleast 3 transducers by now if I didn't have one.
Tue May 26, 2015 2:16 pm
Wed May 27, 2015 10:11 pm
Is gatortail not doing my the reverse transom anymore?
Thu May 28, 2015 6:17 am
Thu May 28, 2015 6:23 am
Guess not. Unless it's only on the extreme? I didn't think to look when I picked it up.
Thu May 28, 2015 7:39 am
Hey man how do you have your depth finder mounted inside your boat? Send me some pics please (229)254-0542
Thu May 28, 2015 7:24 pm
Nice rig and good brew
Thu May 28, 2015 8:46 pm
It's bright enough in that spot that I can rotate it and see from the casting deck.
Fri May 29, 2015 6:22 am
Fri May 29, 2015 6:58 am
Just an update on my review now that I've hunted out of it for 6 days straight. Loaded with me (180), two buddies (250 & 240), dog (55) and all our hunting gear with a beaver tail blind with 35/40# of grass on it still with trolling motor and all the batteries it runs 27 shallow and 25/26 deep. I was very impressed with these numbers.
Sun Sep 06, 2015 5:09 am
Teal season hasn't been great, but I got out and at least broke the boat in for hunting.
Sun Sep 06, 2015 5:11 am
GTR, Waitin' on a DFOU hull
Sun Sep 06, 2015 5:27 am
