36 PD Stock - 16 x 48 Alweld http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=6480 |
Author: | oleman [ Thu Dec 10, 2009 12:05 pm ] |
Post subject: | 36 PD Stock - 16 x 48 Alweld |
MM Brand: Pro-Drive Horsepower: 36 HP Stock FPR PT&T Boat Brand: AlWeld Boat Size: 16 x 48 Boat Layout: Single Seat – No Flotation Speeds | Shallow Water: 29.7 New – 1 year later 26.7 Speeds | Deep Water: 28 New – 1 year later 26.7 Total Boat Load With Gear Etc: One Person, 6 gallons gas Conditions Tested In: 50 degree temp, flat water Comments: Been having it for about 1 year now, no complaints except for lost of speed. Whenever I contacted KP at ProDrive, he has been very helpful. Use it for Duck hunting, drop net crabbing, & Fishing. Duck Hunted in water deep enough to float the decoys, when we parked the boat to hunt, we were not floating and had no problems with shallow water. Ran a mud boat for 30 years, the MM configuration gives you so much more room. Would suggest a MM over a mud boat to anyone ready to buy. |
Author: | basinhunter [ Thu Dec 10, 2009 12:14 pm ] |
Post subject: | Re: 36 PD Stock - 16 x 48 Alweld |
Nice rig ![]() |
Author: | richardb [ Thu Dec 10, 2009 12:37 pm ] |
Nice Clean Rig you're running. ![]() |
Author: | EasTexDux88 [ Thu Dec 10, 2009 1:02 pm ] |
looks good man, nice and clean... go get it bloody or muddy! ![]() |
Author: | Full Throttle [ Sat Dec 12, 2009 7:20 pm ] |
Nice boat..... My guess is your loss of speed is a result of a worn out prop. What rpms you running? |
Author: | oleman [ Sun Dec 13, 2009 9:48 am ] |
Thanks everyone for the reply's Tested the governor, 4150 The prop is not worn, running 3910 trimmed to best speed. If I trim up higher, gain RPM - loose speed. The bottom looks OK, but the transom has about a 3/8" dip in it at the engine. |
Author: | OwenDickeson [ Sun Dec 13, 2009 9:28 pm ] |
Author: | muddoctor [ Mon Dec 14, 2009 3:55 pm ] |
Out of water RPM's should be more around 4350 in neutral warmed up, turn the motor up some. A hook in the hull will cost you speed. Any hooks along the cross ribs? Most likely the hook is you main issue. PW |
Author: | eazy89 [ Sun Jan 17, 2010 6:37 pm ] |
someone explain to me what a hook is? |
Author: | POKER1 [ Sun Jan 17, 2010 6:42 pm ] |
